randyc
Stainless
- Aug 18, 2003
- Eureka, CA, USA
I know that Delrin is sh--ty material for getting a nice finish. Found a discussion from seven years back regarding the problem:
http://www.practicalmachinist.com/vb/general/shining-up-delrin-205013/
Maybe it's a fruitless effort but I wonder if - since then - anyone has devised a process to improve surface finish, such as on the following part, particularly the tapered length:
Three parts, about five inches long with a 4 degree taper starting at .50 diameter at tailstock end (supported with live center) increasing and terminating at around .75 diameter with a fairly large radius fillet blending to the one inch diameter end (held in a collet).
Tolerances not critical +/- .010 but appearance is important. (FWIW there will be three or four subsequent operations in a vertical mill but the resulting surfaces will not be visible.)
Ignorantly, I tried to improve the turned surface on the first part with a couple of grades of paper and made the finish worse. Draw filing helped to a certain extent but basically, what I turned was the best that I got.
I honed and honed the tool and the tapers on the other two parts looked quite a bit better. The job has been put aside for the moment. Fortunately these were rough-turned and there is a bit of allowance on the diameter, left for the magic cutting tool angles, end radius, speed/feed da-da-da-da, if an optimum combination even exists !
Oh yeah, the only lathe with a taper attachment is limited to a top speed of 1200 RPM.
