Hello
I bought a used First milling machine to use in my garage on 200 volt single phase . I had the 550 v 3 phase motor rewound for 220 volt three phase and will run it from a delta vfd-bthat is feed from 220 volt single phase . Connecting the terminals isn't a problem.
The issue is the manual shows a few million programming choices . All I want is to supply 220 3 phase to the motor and have it run at the rpm it is deigned for . I would use the existing forward reverse stop switch the machine came with .
So the question I hope someone can answer is "what programming inputs do I need to do" ? This vfd just came out of the box new .
Looking at the Parameter Manual it looks like this device does a hell of a lot more than I need .
Thanks Ed
Thanks Ed
