Hi,
I want to design and produce part that one of its planes will be fixed and the other plane will be used as a spring for small movements (up to 10 degrees)- photo is attached.
I want the spring to be activated from ~200N.
The manufacturing process that i will use is bending.
Spring length is ~30mm
Thickness- 2mm
I am looking for a suitable material that will for this type of applications.
I know that carbon should fit, but at this point i would prefer it to be some kind of steel with simple bending production process.
If someone is experianced with this kind of applications and can share some information regarding the correct material or some informative articles- that would be great!
Thickness- 2mm
