designing engine accessory brackets - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
  1. #21
    Sep 2017
    Wisconsin
    1,365
    358
    847
    I have guys make them out of wood themselves and then bring them in and I'll make them for time and materials.
    Wood will hold the weight and anyone with a garage can whittle it into a shape.
    It's just bolt clearance holes on these things, and you can always shim for belt alignment later, or take a piss cut off the bracket or something.
  2. #22
    Mar 2013
    Washington
    363
    149
    244
    Reading between the lines here but my guess is he is trying to run a inverter to power the house ac unit.
    500+ amps of 14 volts dc is not a unrealistic load.
    With all the loss and drag im guessing there could be 50 hp of load on that belt...
    You mentioned gm there are 4 bolt bosses near the balancer on the front of the block.
    I would really try to use those as the basis for a plate to carry bought alternators and the tensioner.
    If my guessing is correct then a serpentine is the way to go. You could do it with v belts but you would need several for that load.
    Man I miss this stuff!
  3. #23
    Sep 2006
    SE PA, Philly
    5,603
    1128
    2066
    If you are responsible for part of the design (the measurements) then you are responsible for all of the design (specifically, if it works or doesn't work). Put another way, if you provide measurements for a bad design, the you are responsible for the bad design.
    Just sayin.
  4. Likes digger doug liked this post
  5. #24
    Oct 2010
    Maryland- USA
    4,833
    2373
    3033
    If you don't have enough experience to rein in opinionated clients don't take the work.
  6. #25
    Jan 2005
    Houston
    6,988
    1273
    3996
    It's just bolt clearance holes on these things, and you can always shim for belt alignment later, or take a piss cut off the bracket or something. "
    Oh, the humanity!!!!
  7. #26
    Jan 2007
    Florida
    1,243
    173
    436
    Quote Originally Posted by Trboatworks View Post
    i didn't take it in for this. this is what is called an "add-on".
  8. #27
    Jan 2007
    Florida
    1,243
    173
    436
    Quote Originally Posted by Hbjj View Post
    you're close. his plan is to discard 2 roof a/c's and install 2 dc 48v mini splits (hanging off the bumper), installing a $8k 48v battery that needs special charging. he doesn't need more than a [email protected] alternator so a v-belt would be sufficient but he wants ribbed or serpentine because that's what his boat has. according to him this high zoot battery will power the a/c's for weeks without charging so i don't see the point of the engine driven 48v alternator - assuming he is correct. it can charge off the solar panels he intends to install and from shore power or gen
    (it's not a chebbie)
  9. #28
    Dec 2012
    Se Ma USA
    2,197
    179
    1198
    I keep a portable CMM unit with me at all times. Cell phone camera and take pic with a ruler or two in the pic next to part. Import the image into a CAD as an image and scale image to be correct with model space. Will not get you tenths, but often a useable part to start with.
  10. #29
    Sep 2017
    Wisconsin
    1,365
    358
    847
    Quote Originally Posted by GregSY View Post
    LOL I've been doing race car stuff for a while.
