AdamPrince2
- May 10, 2011
- Honeoye Falls, NY
I purchased 100 3/8" grade 5 bolts with nuts and washers of a known material. I'm going to torque them all to the same torque after ultrasonic cleaning. Then expose them to HCL acid to corrode them in a controlled way for a set time. Finally, I'll apply different penetrating oils to a sample set of 10 with a set of 10 controls and breaking them loose with a torque wrench after a set time.
I need a way to record maximum break loose torque applied. Will I have to purchase a dial type torque wrench with a memory needle or is there a way I could accomplish the same thing with a beam torque wrench?
Thank you
Thank you
