Hello fellow machinists.
I'm having some trouble finding a solution to my issues.
Heres the situation:
I am working with a HAAS UMC.
I am required to create a hole 20" deep, with a diameter of 2.5594" +/- .0004" in two conjoined parts made of A356 T6 aluminum
The two parts are roughed individually, then mated together with press fit pins, and then mounted to the fixture. It is then rough cut with the boring tool again and then finally finished with some very light finish passes. The bore is at the center of the seam.
I have been able to produce good results using a modular single point boring tool. (D'andrea), and I am able to check my results using a sunnen dial bore gage.
My problem is it takes me 10-15 hours to create this bore... I start with a very ugly rough bore and use a .016R nose insert and take .006-.008" off dia with every rough/finish pass. Feeds and Speeds for rough pass is .6ipm and 700 rpm. I have to take about 8 rough passes to get withing .010" of my required dimension. I then switch to a .008R nose insert and take .001-.002" pases and take 4-6 passes to get to my finish dimension Feeds and speeds for the finish pass are .3ipm and 700rpm
If I try to push it any harder or faster, my cutter vibrates and gouges the bore resulting in lost time when I have to remove the part and get it welded for repair.... then rough out the welds individually to somewhat match the bore, then reassemble the two parts, re-setup, and then finally start boring again.
The part is for automotive applications, specifically the crankshaft main bore for a horizontally opposed motor.
My question is.... IS THERE A BETTER WAY???
Can anyone who is in the automotive manufacturing industry or any experts on deep bore holes? Right now we have a french company "ittede" working on a quote for a custom tool but is there anyone out there that is already doing this (or something like this) successfully?
Please help!
Please help!
