capocoreyollo
- Jul 22, 2015
Hello,
Im developing a system for lubricating coil, continuously feeding through a stamping press/die on a roll forming line. The last guy just got some HF pump hooked up to 55 gallon drums at each press, basically flood coolant to the top of the coil as it enters the press. So much waste/mess, and no lubrication to the bottom of the coil. I would like to be able to feed 4 stamping lines from one central location, and im trying to figure out what size pump/GPM's I would need to provide to each press. Is there any trick to sizing such a thing?
In my ignorance, i'd assume the amount of lubricant needed would be determined by the surface area of the material and the rate at which its feed through the die such that ideally, a uniform film would cover both top and bottom surfaces of the coil?
Or does it have to do with the actual punching/ perimeters of the total punching/time?
Material is 3.375" x .025 galvanized steel coil, air fed, through a 35 ton press. I can take a photo of the strip to show the punch pattern if necessary.
I plan on building felt roller lubricators as they seem to be what the industry does. Anyone know where a guy can find ~3" round felt x 5" or so long?
Any continuous metal stamping guys have any incite on the matter?
Corey
Corey
