Gauge
- Mar 25, 2005
- Philadelphia
I have an old BIG Devilbiss air pump that was removed from a compressor in a very old body shop near my house. It's a two piston single stage compressor that weighs about 250 to 300 pounds. It was working when it was removed and seems to still work OK now. Tag says model number 235. A 5HP motor used to drive it.
I have three questions:
1. Can anyone tell me anything about this compressor - age, specs, anything.....
2. It looks like this compressor had some sort of a self oiling mechanism that's been disconnected. There is a small pipe on the side of the compressor and another on the rear bearing. Does anyone know how this is suppossed to work as I would like to get it working the way it was designed to.
3. I think it might be a good idea to hold on to this air pump - especially since this pump alone weighs more than entire compressors I've seen at Lowes or Home Depot. Is it possible to get a rebuild kit for it? Even if it's just the gaskets - so I could tear it down, clean it completely and then put it back together. Why is it that the compressor pump on my 60 gallon Sanborn Black Max is just a fraction of the size of this Devilbiss compressor?
Anyone have any thoughts? I know you guys are always helpful when it comes to anything old and made of iron. Thanks for your help....
