Diacro or Pexto Box break teeth
Likes Likes:  0
Results 1 to 6 of 6
    Oct 2004
    204
    Default Diacro or Pexto Box break teeth
    I have a couple of box breaks which are missing teeth, and I was wondering what the best advice for getting some.
    Either where to buy some, or where to have some made, and what kind of steel for them to be made from.
    Bill
    Jan 2007
    Southern New Hampshire
    1,315
    988
    483
    Quote Originally Posted by wakrocket View Post
    Bill
    I believe the steel is 1045.
    I bought a bunch off eBay to support my 24-in. DiAcro. They would be simple to make, too.
    Mar 2004
    Edison Washington USA
    10,413
    978
    5444
    Both Di-Acro and Pexto would be happy to sell you replacement fingers (which is what they are called)
    But they are VERY expensive.
    Remember, the new price on the little Di-Acro 24" brake is now well over 2 grand, and the 36" is over 3K.
    Ebay is a better bet.
    But if you want factory parts-
    http://www.diacro.com/index.html
    http://www.roperwhitney.com/
    (roper whitney bought Pexto in the 60's or so)
    Feb 2005
    Akron, Ohio
    747
    314
    107
    Hello,
    Made mine with 4140 HT decarb steel plate. The factory prices will take your breath away !!
    Brian
    Feb 2006
    Indiana
    12,979
    689
    3930
    My Di-Acro box and pan brake was missing several fingers when I got it, around twenty years ago. In communicating with the factory, I found there are two completely different types of fingers for the 24" brake. I bought a 6" finger from them, but the price seemed rather high even back then. I later made the narrow fingers that I needed from O-1 tool steel flat stock. That was the most readily available steel bar I could find in appropriate section and short length. I did not think they needed to be hardened, and they work fine. I made the clamps from some thick angle iron that was a good match for the original clamps.
    Larry
    Jun 2003
    Mebane North Carolina USA
    6,720
    53
    1941
    I have a Rockford openside planer. Can make you up a batch fingers from 4140 or another grade as needed.
