Dial indicators
Likes Likes:  0
Results 1 to 9 of 9
Thread: Dial indicators
    Jan 2020
    Georgia
    Default Dial indicators
    I’ve fairly new to machining ( less than two years experience)
    I really struggle with using dial indicators on round parts ( finding the OD, ID of a circle )
    Was wondering if anybody had any tips or videos I could maybe use to improve my ability to use it!
    Thanks again
    Jan 2020
    Georgia
    It’s more finding the x0. Y0. That I struggle with when doing bolt hole patterns , counter bore etc.
    Jun 2012
    Michigan
    10,210
    3462
    3646
    You can get point sets.
    Dial Indicator Tips | Dial Indicator Point Set - LittleMachineShop.com
    Sometimes a test indicator is good, but thy don't tell true travel.
    Jan 2017
    Oregon
    2,771
    491
    1969
    Quote Originally Posted by Rod10290 View Post
    Just practice. Bring your indicator down to just above the part, and sweep it around. Make your big adjustments. Then bring it down, do X first. Zero the dial on the first side, rotate 180 degrees and read the dial. Move X axis 1/2 the amount. This is center X. Rotate the spindle 90 degrees. Now adjust Y axis until the indicator reads the same number. That should be center Y.
    Now sweep 360 degrees and check all around the circle. You should be within .001".
    May 2019
    574
    148
    222
    Only pay attention to X-,X+,Z-,Z+. If the hole is round everything else will take care of itself. Just like indicating a 4 jaw.
    May 2008
    SOUTH AFRICA
    1,627
    1191
    667
    The easiest is to work on only two points at first and then 3. So either the two X's or the two Y's. Then dial in any other oposing X or Y. It will tell you pretty quickly how round the "circle" is.
    I made a few of these similar to this for a "finger clock" as we call it here. https://www.mscdirect.com/product/details/01386168
    Aug 2018
    Here's a couple of videos that show indicating a hole.
    YouTube
    YouTube
    Aug 2006
    Wisconsin
    1,649
    741
    739
    Nov 2013
    Utah
    4,674
    1238
    2618
    Quote Originally Posted by Hardplates View Post
    Actually assuming the hole is Round, you really only need X+X- and Y-. Three sides to see.
