AllTheGearNoIdea
- Dec 22, 2019
Hi all,
I'm currently trying to design some gears for an automotive transmission which involve working with a fixed imperial center distance of 2.8 inches. Mathematically the only "standard" DP value that I can use with this center distance is 10. This not only limits the ratios I can choose from, but it also limits the strength of the gears as a DP 10 tooth is quite small for an automotive transmission.
Looking at the maths, I can also use a 6.25, 7.5 and 8.75 DP gear, which essentially solves the issues above. My only problem with this is that I am unsure if these are standard DP values that a gear manufacturer may have a hob or a shaping cutter for. I'd rather not design gears for a low volume product which will require special hobs / shapers to be made for them!
I feel as if DP values at quarter inch increments between 6 and 10 DP can't be rare, especially in the automotive world. However I am finding it very difficult to find any reliable information anywhere on the net that can confirm this or explicitly deny this.
Looking at some performance transmission suppliers websites, they offer a large variety of ratios for use in the same transmission. Assuming a fixed center distance and working backwards using the tooth counts, different gear pairs give different non-standard but sensible DP values such as 7 and 5/6th DP and 8 and 1/6th DP.
Does anyone know if sensible non-integer DP values are used in the industry on a somewhat frequent basis if at all? Or point me in the direction of somewhere that discuss or proves this?
Thanks!
Thanks!
