zamboni2354
Cast Iron
- May 26, 2008
- Long Beach, CA.
Hey guys. I just received a new Baldor 500 tool grinder. I took the wheels off my old Delta and put the regular wheel on one side and was going to put the diamond wheel on the other side but it wouldn't go on. I tried both sides. I then ordered a norton diamond wheel and it also wouldn't go on. I measured the norton ID at 1.250. I then measured the hub on the grinder. One side was 1.251 and the other 1.2505 i think. Seems to me the hub should be slightly smaller than the hub? The green wheel with its 1/8 plate backing did fit, barely, but the thicker aluminum on the diamond wheels just wouldn't go. I called baldor and they told me to call the distributor. Has anyone ran into an issue like this?
Sent from my LM-V405 using Tapatalk
