Hi guys,
I started to wade through the information online about springback and K factors but figured I'm going to get an easy answer here I hope you don't mind me being lazy.
I'm going to build a simple sheet bending unit for my press. Consisting of a V die, pillars either end, and springs around them holding a punch above it, maybe 400 long.
What angle should the die and punch be for 90 degree bends in 1-10mm steel/aluminium? Lets say more realistically 1-5mm steel and aluminium - though one day it'll get used for something bigger than it should be no doubt. I realise this is broad but for a home machine shop doing the sorts of stuff we do.
Not much of what is available online is actually specified. Am I better off going to 88 degrees and being careful with the lighter stuff, or...?
Thanks as always!
Thanks as always!
