TravisR100
Cast Iron
- Aug 7, 2006
- Houston, TX
I've seen one successfully done using an arduino and one with a development board from TI. Neither of those have posted parts and code however.
This is interesting to me. I don’t know enough about instrumentation to build my own, but I would love a readily adaptable tach kit that could be installed on lathes and mills. There are multiple postings on the web about building your own, but no simple kit that I have ever found.
My machines are 3 phase running off of VFDs and the original manual speed controls. Now I calculate in my head for approximate rpm and comvert to sfm as needed. That's a bother.
You can get a digital tachometer kit on amazon for $15-20 that will easily read manual lathe/mill speeds. The rub is they require a little magnet mounted for the pickup. On my lathe it was easy though, file a flat spot on one of the spindle nuts and stick that magnet on. No need for adhesive or anything up to 1800 rpm. A project box and wall wart power supply round out the list of needed parts.
At least on a non-VFD driven lathe, there are a distinct number of speeds so the need to have a tach is minimal.
Any RPM over 100 is shown in 100 RPM increments? Why bother having a tach, then? There's a massive jump from 101RPM to 202RPM...it'd be nice to know just where you lie therein. Then...if you have a tach that's too sensitive it's also near-useless as all you get is a jumble of numbers constantly.
Notice
