DIN 74-Af3 ? help please
Likes Likes:  0
Results 1 to 8 of 8
    Apr 2004
    Mesa, AZ
    162
    Default DIN 74-Af3 ? help please
    I have a print from Germany(I think). It has a couple callouts I cant figure out and my google-fu is failing me
    DIN 74-Bf4
    DIN 74-Af3
    As far as I can figure out DIN 74 means it is a 90 countersink hole and thats what the print looks like it is showing, what I cant find is what the Bf4 and Af3 mean?
    I have an ISO hole chart and thought thats what the f3 and f4 were maybe referencing, but I dont see either on the chart.
    thanks for any help
    Mar 2005
    Germany
    494
    49
    Check here:
    Sektion Physik, Zentralwerkstatt, template
    A and B refer to the Din-standard for the fastener
    f is for "fine" (as opposed to "medium")
    3 and 4? no idea.
    Benta.
    Apr 2004
    Mesa, AZ
    162
    Thanks Benta.
    Feb 2008
    Illinois
    1,107
    65
    395
    DIN 74 Bf4
    90deg. c'sink for countersunk socket head screw DIN 7991
    Form "B"
    Execution: fine
    For dia. 4mm
    Hole dia 4.3mm H12
    Top dia 8.3mm H12
    Depth of c'sink approx.2.4mm
    Straight from the top surface before the 90 deg starts 8.3 H12 mm dia, 0.3mm+0.1 deep.
    DIN 74 Af3
    90deg. c'sink for countersunk head screw
    Form "A"
    Execution: fine
    For dia 3mm.
    Hole dia: 3.2mm H12
    Top dia.: 6mm H12
    Depth of c'sink: approx. 1.7mm
    Straight from the top surface before the 90 deg starts 6 H12 mm dia 0.25mm+0.1 deep
    Note: Form"B" is for 90 deg. c'sunk socket head screws as per DIN 7991.
    Form"A" is for 90 deg. c'sunk screws as per DIN 963, 965.
    Also for "raised c'sunk head srews" as per DIN 964,966
    Also for c'sunk screws as per DIN 7513,7516, 7500
    C'sunk wood screws as per DIN 97 and 7997.
    Raised head c'sunk wood screws as per DIN 96 and 7995.
    It would be a good idea if you could find the exact DIN number of the screw
    they plan to use for Form "A" and for Form "B".
    Apr 2004
    Mesa, AZ
    162
    Thanks Juergenwt, that will do it.
    Jun 2019
    Halo morning...
    can u tell me DIN 47 kf6 ? help please
    Feb 2008
    Illinois
    1,107
    65
    395
    Are you sure about your numbers?
    Ra-Rz Conversion DIN 47
    Jun 2019
    how about dimension ? As I know got dimension .. the pin hole one
