Dirty power - The lathes are knocking out my air conditioner - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #21
    Aug 2014
    bainbridge island
    1,129
    213
    267
    how much is your time worth?
    i think you should try a line reactor in front of the AC unit along with line to line and line to ground capacitors.
    but.. is there signal wires that run a long distance from the ac unit to another location? is there an air handler that is powered off a different circuit breaker? your line conditioner is also an isolation transformer and would help solve that problem.
    I think you need to call up the manufacturer of the lathe's vfd and talk to them. it may be that various components internally have failed, or are ready to fail further and blow the drive.
    can you install a braking resistor and disable regeneration?
  2. #22
    Oct 2017
    535
    136
    143
    A dumb way to check for supply line noise is to put a low value capacitor in series with a speaker across the line. Listen for beeps, woops, kshshs, or screes.
  3. #23
    Nov 2006
    Southern California
    976
    5
    105
    Quote Originally Posted by J&H View Post
    So we've tried a few caps line to line with no difference. I got ahold of a Sola HD 5000va line conditioner and have it feeding the AC unit and it's working now, the lathes don't bother it one bit anymore.
    The downsides are that the conditioner is fairly loud, not a big deal when the machines are running though and it also pulls about 2 amps continuous. That kinda kills the efficiency of the fancy AC unit. I may wire in a couple switches so it can be bypassed when the lathes aren't running or won't run for a couple days...
    Sola line conditioners are amazing. I worked in a lab in a bay with a 50 ton crane. When they ran the crane all the instrument reading would go berserk. Adding a Sola power conditioner totally eliminated the erratic measurements.
