Dumpster_diving
Cast Iron
- May 18, 2017
- Massachusetts
I've fabricated a replacement door handle for a 1930's refrigerator out of tool steel.
The raw steel has a bright clean surface finish but for long-term appearance, wear resistance, and corrosion protection I'd like to nickel plate the piece.
I've got an electroplate kit from Caldwell with the nickel plating solution, but I'm guessing that beyond degreasing and cleaning (with some acetone) prior to plating, it would benefit from a light pickling prior to plating. It's a freebie project for a friend so unfortunately I can't send it out for plating.
Any suggestions for a suitable home-brew pickling solution? White vinegar and salt? Alkaline (like sodium hydroxide)? Skip the pickling and call it good-enough?
Thanks in advance.
Thanks in advance.
