DoAll 16-3 Vertical Bandsaw with Hydraulic Table Motor Voltage Question
Likes Likes:  0
Results 1 to 15 of 15
    Dec 2017
    ALAND ISLANDS
    56
    8
    Default DoAll 16-3 Vertical Bandsaw with Hydraulic Table Motor Voltage Question
    I have come across a DoAll 16-3 bandsaw with the hydraulic table. The data plate says it's 440V. I am looking for information on whether the motor is dual voltage or not. The seller sent me pictures but the only numbers on the motor are F106/3830, MG1000G27. The serial number is 124-59276 so it's a 1959 year model. Does anyone have information on this version saw.
    Thanks in advance.
    Will
    Jan 2003
    Imlay City, Michigan
    1,952
    99
    205
    Here's a link to the manual...…
    https://www.doallsaws.com/manuals/16...s%20Manual.pdf
    I'm pretty sure the motor will be dual voltage? All of the DoAll saws I have had were dual voltage.
    Kevin
    Mar 2012
    Geilenkirchen, Germany
    2,467
    1465
    1240
    Quote Originally Posted by bsg View Post
    Kevin
    Most of the DoALL motors are GE 12 wire motors. The field coils can be wired in series (high voltage) or in parallel (low voltage). Pull the wiring cover and count the wires if all else fails. Further, there should be a wiring diagram on the inside of the cover.
    Aug 2007
    GA
    758
    129
    I have the same model saw and it was dual voltage
    Oct 2006
    Woodland Hills, Ca. and some times Hutchinson, Ks.
    2,328
    19
    592
    I also have a 16-3 from 1964, the motors drive and coolant are dual voltage. The welder may be single voltage? I have both 480 and 240 three phase, mine is powered 240 due to the welder situation.
    Steve
    Aug 2007
    GA
    758
    129
    I'm pretty sure the welder on my was reconfigurable to 230
    Aug 2007
    GA
    758
    129
    Also, in case you didn't know, you need to run the varidrive speed down to the minimum (while the motor is turning) to be able to shift the trans as there is a lockout.
    Dec 2017
    ALAND ISLANDS
    56
    8
    This is great guys! Thank you so much. I am finalizing the deal now. The seller did open the motor cover and there are 12 wires so this is dual voltage as you stated. More to learn about this machine but it looks to be in decent shape from the pictures. Thanks again!
    Will
    Jul 2004
    Houston, TX USA
    30,461
    All are 240V single phase, however you achieve that
    Dec 2017
    ALAND ISLANDS
    56
    8
    Thanks Steve. I am going to wire for 240. May have to reach out to you wiring configuration if I can find a diagram.
  11. #11
    Dec 2017
    ALAND ISLANDS
    56
    8
    Good to know. I was not aware of this. Thank you.
  12. #12
    Jul 2004
    Houston, TX USA
    30,461
    The welder will have a DBW number and there are a number of schematics
    Here is a DBW 15 - possibly too low res to read
    Attached Thumbnails Attached Thumbnails welder-feed-schematics.jpg   elec-schematic-dbw-15.jpg   welder-feed-schematicscrop.jpg
  13. #13
    Dec 2017
    ALAND ISLANDS
    56
    8
    Does anyone have a copy of the manual for the 16-3 with my features and possibly the electrical schematic that I can get?
  14. #14
    Oct 2006
    2,328
    19
    592
    Call DoAll,
    They sent me an electrical diagram of my exact machine.
    Steve
  15. #15
    Aug 2007
    GA
    758
    129
    I have both manuals, but I got them from a basic web search. If you are not able to find them let me know
