Results 1 to 9 of 9
11-21-2019, 11:44 AM #1
DoAll bandsaw model number - what does it tell me?
I am thinking about a DoAll 1612-U. I realize it's a 16" bandsaw. What other information is encoded in the model number?
metalmagpie
11-21-2019, 11:58 AM #2
The 1612 refers to throat depth and vertical height. Throat meaning blade to frame dimension and height meaning max height of work possible. On 2 wheel saws throat is effectively the diameter of the wheels. Throat dimensions greater than wheel diameter require a third wheel. The - "U" refers to the specific configuration and that along with the serial number specifies the correct replacement part when ordering.
11-21-2019, 12:20 PM #3
Don’t buy that one. I’m not an expert but the -U is some stripped down saw for meat cutting or something, I don’t know. The top of the line would be the 1612-3. The -3 will have the hydraulic table and the transmission. -1 does not have hydraulics, may have the transmission not sure. I think they made a -2 option also don’t know. Hold out for a 1612-3 it won’t cost much more if any and will by 3X the saw.
11-21-2019, 02:42 PM #4
Here's a link to a manual......
https://www.doallsaws.com/manuals/16...s%20Manual.pdf
The first two numbers after the dash in the serial number are the year it was made, that model started production in 59' and went thru 68', brought back later in a different configuration.
Not a bad saw, it is just a little lighter that some of the other DoAll saws, parts are pricey, just make sure there are no issues unless your getting it cheap!
Post some pic's if you get it?
It is a metal cutting saw with a two speed transmission, just a light duty version compared to the other Doall 16" models.
Kevin
11-21-2019, 02:49 PM #5
Apparently the -U designator means "Utility". This machine's serial number includes -61 so I believe the saw was made in 1961. It has a blade welder and may have part or all of the weight power feed accessory. It does have the little wheel below the speed adjust wheel, which I believe changes the force on the power feed. The pics I have access to do not show the front where a pedal would be. There is some kind of mount bolted to the table which looks like it could be part of the powerfeed.
The saw has a 2 speed gearbox and Reeves drive.
The price is OK, medium 3 digit number.
I already have a Rockwell Delta 20" saw model 20-365. Same 2-speed gearbox and Reeves VS drive.
This saw is on the other side of the state.
16" DoAll verticals don't show up very often where I live.
metalmagpie
11-21-2019, 03:29 PM #6
These saws are a bit scarce everywhere, but these models have been made for many, many years in multiple configurations. Yes, spare parts from DoAll are expensive. Unfortunately, many of the parts for these are no longer available. These saws are also very durable and will withstand a very high amount of abuse. I have just completed a complete restoration of a military model of a 1612. It has been a 5 month effort, but it now looks and functions like a new saw. There is a parallel thread that I started on the external power feed parts. If you have an interest, it is worth a read. I have to personally thank John Oder for his very valuable contributions.
I received from Scott Olson of DoAll yesterday that these feed parts are no longer available. Scott has been very kind and often, when parts are no longer available he has often given me a copy of the drawing of the part so I could reproduce it.
11-21-2019, 10:37 PM #7
Take a look on ebay. There is a 1612-U and 1612-3. Compare the two and you will see there is no comparison. The -U is a lighter frame, a different shape, no tach, etc. It may be an OK saw but it’s not in the same category as the other DoAll products.
11-22-2019, 07:51 AM #8
All Doall's are meat cutting saws if you don't watch what you're doing...
I have (I think) a 1612-3 and it does not have a hydraulic table. It does have the three speed gearbox.
11-22-2019, 04:26 PM #9
I have a model 16-SFP. Serial # says 1957. Came with welder, tilt table, miter attachment but no weight feed. Any one know what the SFP denotes? Saw was neglected when I got it but refurbished, repaired and re-motored to 2HP it's been a good medium duty machine..........Bob
