Doall v-16 weight
Likes Likes:  0
Results 1 to 11 of 11
    Feb 2007
    Kansas
    641
    5
    15
    Default Doall v-16 weight
    Does anyone know an exact weight for a Doall V-16 Countour Machine bandsaw? I found a manual, but it didn't mention the weight.
    Apr 2004
    Modesto, CA USA
    7,730
    1383
    FYI There should be a threaded lifting ring hole on the top of the arm. I believe it is 3/4" thread. Never lift from the table.
    I believe it is around 1200 pounds or less?
    I think the army training manual is for a doall bandsaw.
    Bill D.
    on edit:
    DoALL Co., Inc. - Publication Reprints - US Army DoALL Model 1612 Bandsaw Instruction Manual | VintageMachinery.org
    Doall Band Saw Model 1612 - The Garage Journal Board
    Jan 2010
    Canada
    350
    62
    173
    I think it's 1500
    Jul 2004
    Houston, TX USA
    31,206
    My 3613-2 from '73 weighs 1400 - and has a bit more metal than a 16
    Nov 2007
    marysville ohio
    10,042
    2857
    6705
    You really need to know how old it is, my 16" DoAll from '56 weighs over 2000 lbs
    Feb 2007
    Kansas
    641
    5
    15
    Quote Originally Posted by moonlight machine View Post
    It's a 1942. I think the correct model is V-16, but not 100% sure. I seem to remember it saying Contour Machine on it too.
    Nov 2007
    marysville ohio
    10,042
    2857
    6705
    Quote Originally Posted by oliverdude View Post
    If it is from '42 it is a HEAVY sob. There was nothing on that saw less than 1/8" thick, even the doors over the wheels. On mine the plate on the floor that the whole thing is built on is about 36" x 36" and 3/4" thick!
    Apr 2004
    Modesto, CA USA
    7,730
    1383
    Model is a 1612. 16" saw with 12" depth of cut. Not sure exactly where the vs is placed. If it has a welder or contour kit onboard that probably adds some letters/numbers to the model name.
    Bil lD
    Jul 2005
    Eastern PA
    1,040
    185
    695
    I can tell you that it is way bottom heavy and gives a Dodge 2500 PU no problems whatever...........Bob
    Nov 2007
    marysville ohio
    10,042
    2857
    6705
    Quote Originally Posted by bhigdog View Post
    How new was the one you hauled in your truck? I know the new ones are much lighter especially up high. I contract at a place that has a 16" from 1990 or so and it is amazing how much lighter it is than my 1956. When I bought mine I hauled it upright in the bed of a 2500 truck from Lancaster Pa. to Ewing Nj. and it was a harrowing experience. That truck felt like it was going to roll over at every turn. The next time I moved it I took the table off and laid it down with suitable wood blocking. I used the same truck to haul it from Nj. to Marysville Ohio on the Pennsylvania turnpike through what passes for mountains out east with absolutely no trouble at all. Unloading was another matter though. We loaded it with a fork lift and it was easy, not so much getting it off. I backed into my garage and put 2 4x4s through the roof trusses and a 1 ton chain fall to the lifting ring. I used a 1200lb capacity engine hoist on the bottom and was just barely able to lift it enough to drive the truck out and lower the engine hoist to stand the saw up all the while the wood holding the chain fall was creaking and sounding like it was about to snap.
  11. #11
    Apr 2004
    Modesto, CA USA
    7,730
    1383
    There is a 36" doall on eaby now that they will ship by first class mail. I do not think it will fit in a flat rate box.
    Bill D
