Does a 12" Di-Acro shear need the hold-down?
Results 1 to 7 of 7
    Jul 2020
    New Jersey
    6
    5
    Question Does a 12" Di-Acro shear need the hold-down?
    I found what looks like a great deal on an older Di-Acro 12" shear, but it's missing the entire hold-down assembly. I've seen quite a few like this on eBay so it seems like a common part to go missing.
    I realize the shear will work much better with the hold-down, but my question is can I still use it reasonably well without it? I have a job coming up and need to cut some 0.020" aluminum sheet and was hoping I could at least limp along without it for a while.
    Mar 2009
    Brunswick Oh USA
    4,813
    5732
    2926
    Quote Originally Posted by JeffThompson View Post
    Jeff,
    Mine doesn't have the hold down either and not sure if it'll fit. Been going to call and find out, but never have.
  3. Likes JeffThompson liked this post
    Oct 2009
    Louisville, KY, USA
    1,205
    224
    331
    I can't imagine it will be an issue with .020" aluminum.
    As you get into harder and thicker materials it starts to matter more.
  5. Likes JeffThompson liked this post
  6. #4
    Feb 2006
    Indiana
    14,102
    827
    4830
    I have had a 24" Di-Acro manual shear for decades. It did not have a hold-down when I bought it. I did a tear-down and paint job and mounted it on a portable bench. My 24" Di-Acro box and pan brake is on a matching bench. I used the shear that way and got by, but I seldom use it. I got a hold-down on eBay and then found it would not fit because the blade was a nonstandard height. So, I used the shear without a hold-down for around twenty years. A few years ago, I decided to spend the money for a new (correct) blade from Di-Acro. That let the hold-down work, so I installed it and I suppose the shear is a little better to use now. Anyway, the next owner will get a really nice shear.
    Larry
  7. Likes JeffThompson liked this post
  8. #5
    Sep 2005
    Northern California
    1,152
    195
    On the 24" diacro I'm not absolutely conviced that the hold down is an enhansement when shearing material that is appropriate to the tool.
    If you are working close to max capacity the hold down might be useful.
  9. Likes JeffThompson liked this post
  10. #6
    Feb 2007
    St. George, Utah
    1,494
    1000
    1040
    Is the Di-Acro way different in design? I use a Tennsmith 48" shear and when the hold-down is out of adjustment or sticky its hard to get precise cuts because the material shifts during the cut. That's with copper and SS.
  11. Likes JeffThompson liked this post
  12. #7
    Jul 2020
    New Jersey
    6
    5
    Thanks everyone! Sounds like, unless I'm pushing the max capacity of the shear, I should be alright without the hold-down.
