Does anyone have any experience with machining Dowmetal?
Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Aug 2004
    Virginia
    2,371
    178
    931
    Default Does anyone have any experience with machining Dowmetal?
    An acquaintance of mine that I used to work with has asked me to duplicate a broken balance beam on a piece of analytical equipment. He says that it was originally made with dowmetal which he can supply. He is currently in Sydney so I don't want to commit until I know a bit more about what I am getting into. I did a little research and found that it is a magnesium alloy but can vary widely in the content and I couldn't find anything on how it machines. The job would incorporate milling and lathe work but nothing overly complicated. Has anyone out there ever worked with this material and comment on the machining capabilities? Thanks very much.
    Jul 2006
    Hillsboro, New Hampshire
    7,842
    1831
    5515
    If the bulk is Mg, then (while I can't guarantee it) it's likely to machine like a more brittle Al. In other words, fairly easy when using sharp tools at moderate RPM and feeds.
    Keep the work are clean, frequently remove chips, and check your programs (if CNC) to make sure you don't have a crash that could send sparks into the chips. Store chips and small waste in sealed steel cans, large pieces are not a hazard.
    Nov 2009
    Massachusetts
    387
    130
    If it was intended for construction of balance beams, it will be quite stable dimensionally (no strange phase changes over time or temperature) and most likely will be easy to machine with sharp HSS tools.
    From Quora: "Dow metal is an alloy of magnesium. It constitutes more than 85% of magnesium and remaining are aluminum and manganese. ... Dow metal : A brand name applied to any of various magnesium alloys containing more than 85 percent magnesium, characterized by extreme lightness."
    Aug 2004
    Virginia
    2,371
    178
    931
    Thanks guys. Joe, I got the same definition but nothing about how it machines. My normal procedure, on what I deem mystery metal, is sharp HSS but I thought someone may have some experience with it. Thanks again.
    Nov 2009
    Massachusetts
    387
    130
    Quote Originally Posted by crossthread View Post
    There was recently another thread on machining pure magnesium. The danger is that magnesium chips burn nicely, hot enough to destroy the machine tool. And perhaps burn the shop down. The problem is that magnesium can burn underwater, stealing the oxygen from H20 and releasing hydrogen. Using cutting oil (not oil emulsion in water) excludes oxygen from the magnesium, and keeps it cool while cutting.
    Jul 2006
    7,842
    1831
    5515
    Quote Originally Posted by Joe Gwinn View Post
    I did a lot of aerospace Mag work (still have a pair of Faraday Cups working just fine on the WIND satellite since the Nov 1994 launch), and never used coolant or oil for machining. Dry cutting, performed as described in my previous post. For small jobs like what's being described, keep it simple and keep the machine clean.
    Don't spark and life is good...
  7. Likes rcoope liked this post
    Nov 2009
    Massachusetts
    387
    130
    It sounds like the OP is making only a few, so just being careful could work. But don't allow the chips to accumulate.
    For machining zamak zinc-aluminum alloy, I found that to get a good finish it was essential to continuously blow the chips away with compressed air. This can be combined with a shop vac. Which may prove sacrificial.
  9. #8
    Aug 2004
    Virginia
    2,371
    178
    931
    I am just making one. Thanks Joe.
  10. #9
    Jan 2012
    Midland, Texas
    1,501
    498
    765
    Is that anything like Rearden Metal?
    Sorry...
  11. #10
    Nov 2014
    Florida
    4,071
    1613
    1891
    Why do people seem to always say "sharp HSS"..? Why not sharp carbide? I mean I guess if you are using a bridgeport you don't get the full effect of carbide (not enough rpm, un-controlled feed, etc)
    Uncoated 3 flute carbide endmills will be as sharp as HSS, and likely to hold their edge better too.
  12. #11
    Jul 2006
    7,842
    1831
    5515
    It's a bit of a holdover from earlier, coarser grain carbide tools. Back in the day HSS were sharper, because the larger grains in carbide didn't support a keen edge.
    Now, with smaller carbide particles a sharper edge can be held, lessening the gap to HSS. But at the extremes, a HSS tool, with it's still-smaller microstructure can take a sharper edge. How long it keeps it over carbide in similar cutting conditions is another story...
  13. Likes Mike1974, MetalCarnage liked this post
  14. #12
    Nov 2014
    Florida
    4,071
    1613
    1891
    Maybe very good brand name HSS (niagara? - OSG... etc) but I have used alot of junk HS too, that wouldn't cut you a slice of bread. On the other hand, never seen badly sharpened carbide new- from manufacture, re-grinds well... )
  15. #13
    Jul 2006
    7,842
    1831
    5515
    Yeah, a lot of current HSS comes from foreign production that's sorta crap. I won't buy HSS on Ebay unless it's a reputable NOS US brand, as you have to worry about counterfeit packaging with the newest stuff.
  16. #14
    Aug 2004
    Virginia
    2,371
    178
    931
    Well Mike I have never heard anyone say "get yourself a nice dull HSS tool" but I have found that a very sharp HSS tool is sharper then most carbide bits. In my opinion HSS still does a better job on some material. I am talking lathe here not mill. I also like the fact that after the almost complete demise of Armstrong type holders, it's a lot easier to adjust the rake angle with HSS then carbide. It only takes a minute to regrind an HSS bit to eliminate heel drag or chatter. With a carbide bit in a QCTP you are pretty much stuck with what you've got. I'm not trying to be old school or anything. Carbide is amazing and if you have the power you can drive it like you stole it.
  17. #15
    Nov 2014
    Florida
    4,071
    1613
    1891
    Have you used any aluminum specific inserts? Those things are fucking sharp!!! I mean like look at it wrong and you got a cut on your finger. HSS has it's place (drills, taps, etc) but for outright cutting stuff.... carbide all the way!
    Can't find a linky now... but you should look them up. I bought some aluminum specific inserts for a boring head and I cut myself installing the insert on more than one occasion..
    In bold - if you dull/hone a flat on the edge on a HSS drill for some brass/copper/bronze it does work better.
  18. #16
    Jul 2004
    Houston, TX USA
    30,274
    Do read and take seriously the parts about fire hazard - and the simple ways to circumvent that. Ignore and be prepared to get the scare of your life - a rapidly blossoming brilliant white fire impossible to put out - and making it tenfold worse - in the most spectacular way - if you douse it with water
    There are (or were fifty years ago) purpose made dry compounds (think floor dry similar) useful in smothering the conflagration
  19. #17
    Nov 2009
    Massachusetts
    387
    130
    Quote Originally Posted by johnoder View Post
    Use sand or kitty litter.
  20. #18
    Sep 2006
    SE PA, Philly
    5,352
    1001
    1795
    Joe, I think that the attractiveness of Mg/Dowmetal for the balance beam application is its low weight. I believe it has about the same coefficient of thermal expansivity as Mg, that is about 70% higher than steel. That coef is nearly as high as Al.
  21. #19
    Nov 2009
    Massachusetts
    387
    130
    Quote Originally Posted by bosleyjr View Post
    Low weight is certainly desirable, but so is dimensional stability. Some metal alloys have complicated crystal phases, which change abruptly over temperature, when phase conversion occurs. I saw a big discussion about this on the design of a high-sensitivity pendulum-based tilt sensors, one that could measure long-term seismic motion of the ground, but no longer recall the details.
    Added: It was the Taylor/Hobson units called Talyvel Clinometers.
  22. #20
    Virginia
    28,165
    7561
    8718
    Might be thinking of the GI-ubiquitous "Purple-K"?
    Standard-issue around combat airfields & crash trucks "back in the day". Or our Oxygen & Acetylene plants. Still widely used. Works rather well.
    Usta bee, big bare-iron hayrake wheels, tank of the powder, Nitrogen cylinder to heave it a fair distance was our "nuclear option".
    ISTR is it sort of ablative?
    Purple-K - Wikipedia
    Anyway, it can leave an air-excluding crust that's a lot more useful than porous sand, kitty-litter, diatomaceous Earth, or vermiculite.
    Even if it pretty well trashes whatever survives of what it is used on, it has saved a LOT of lives and avoided worse disasters, yet.
    That said, Magnesium has gotten plenty of NEW attention since it is more recently found all around us, not just in warbirds or wormbirds (VW beetle engines..).
    Firefighter Training: Extinguishing Magnesium Fires
    Worth preparing to reduce the risk of more "Bad News".
    I'd far rather grumble about extinguishers bought and never needed than the other outcome.
    The day twenty-two OTHER extinguisher had failed to even slow-down a damaged
    Acetylene production plant hopper fire. Until one brave man went right into the fireball with an Axe to get the hopper wreckage clear to pour the Purple-K to it.
