MichaelP
Titanium
- Dec 7, 2008
- IL/WI border
Check the distance between the pivot and cylinder of the movable anvil, I have one that is 1" and one that is 2", I believe the chart is for 1" distance.Thanks Mud. Am I assuming correctly that the same table is valid for either model of external Taper Mike?
I'd use a parallel between the taper and the anvil, you'll probably need 3 handsWhat is the easiest (handiest) way to measure tapers shorter than the anvil / sine bar?
These were made in at least 4 sizes,I have the smallest,will do Morse 4 but doesn't open far enough to do #5. Would like to have the next size up and the internal one. My machine tool dealer friend has what I call size 3 and 4,great for doing large boat prop shafts!! The original box lid has the mic readings for the various taper sizes etc.
John - are these what you call the 3 and 4? One does 4" to 6", the other is 10" to 13" (approximately)
If anyone here needs the big one, I'll trade it for an internal model. You can shim it with 123 blocks for smaller parts.
View attachment 201403View attachment 201404View attachment 201405View attachment 201406
I see. I didn't know they existed in different sine bar lengths. Will need to do some calculations to confirm what bar length the table is for.Check the distance between the pivot and cylinder of the movable anvil, I have one that is 1" and one that is 2", I believe the chart is for 1" distance.
My outside TaperMikes all have 1" sine bars. The tables I created are copied from the instructions that came with the outside mikes, so they are for 1" sine bars. If you look at the inside TaperMike picture I posted, you will see it has a longer (2") sine bar. And the picture of the outside TaperMike I posted has the original instructions on the aluminum plate inside the box lid.I see. I didn't know they existed in different sine bar lengths. Will need to do some calculations to confirm what bar length the table is for.
Notice
