Does EN19T or EN24T respond well to burnishing?
Results 1 to 19 of 19
    Oct 2006
    United Kingdom
    278
    129
    6
    Default Does EN19T or EN24T respond well to burnishing?
    I'm going to make a milling spindle for my lathe and would like to use angular contact bearings in the rear, and a needle roller bearing at the tooling end - inspired by the Deckel vertical spindle. I'd like the needle rollers to ride on the spindle.. I'm pretty set on this layout for milling.
    I'd like to make it from EN19T or EN24T and wondered if either of these would be reasonably hard wearing (as a bearing inner race surface) if lapped then burnished where the needle rollers ride?
    The milling spindle would be used only occasionally, driven by 1/3hp motor, ISO20 taper.
    Thank you
    Jan 2007
    Norfolk, UK
    20,088
    15491
    15842
    IME (of seeing others attempts ) nowhere near hard enough for needles to run on, if you can use needle rollers with an inner track
    FWIW, with a milling spindle you will be far better off with taper roller or angular contact, etc etc bearings.
  3. Likes 4GSR, J Grainger, eKretz liked this post
    Oct 2006
    United Kingdom
    278
    129
    6
    Taper rollers look much more suitable but needle rollers at the front end will fit..
    The housing needs to be small enough to fit on a Myford type vertical slide and I wanted to use ISO 20 for the taper - ISO 30 would be nice but too big and MT1/MT2 isn't really a milling taper.. I'll use 8mm watchmakers collets via an adaptor too.
    I could use a different grade of steel and send it off for heat treatment but pre-hard is pretty straightforward to machine. Is there something else machinable which would be better?
    Jan 2007
    Norfolk, UK
    20,088
    15491
    15842
    Have you thought about using ER Collets direct on the spindle,.......... I built a 1/3hp milling spindle nigh 30 years back and went ER (1/2'' or 13mm Cap) direct in the end, and have never regretted the choice.
  6. Likes 4GSR, J Grainger liked this post
  7. #5
    Jul 2006
    Hillsboro, New Hampshire
    9,618
    2253
    6658
    Figure out how to use something like this as your spindle:
    Techniks CNC Machine Tooling | ER Holder Extensions
    Essentially as per Citrus Sam above.
  8. #6
    Oct 2006
    United Kingdom
    278
    129
    6
    The ER spindle is a good idea but I'm fancying also being able to use some bits of tooling from my watchmaking lathe, and would make a couple of arbors for the ISO20 taper..
    Will see if we have anything hardened at work nowadays, might just give it a go in prehard - a housing can be reused with a new bearing spacer.
  9. #7
    Jul 2007
    UNITED KINGDOM
    5,081
    2920
    2510
    Neither of them will be hard enough in the T condition. If you don't want to risk re-hardening+tempering them with heat/salt bath+quench+temper then the cost of gas nitriding is quite reasonable.
    I'm going to be sending out a gear and a splined milling machine spindle drive collar for this in the near future for my milling machine that I'm still rebuilding. Both are EN24T, but can be surface hardened significantly with the nitriding process.
    The alternative is either inner tracks or angular contact/taper roller bearings at the tooling end. Presumably you are constrained by the available inside and outside diameters? If that is the case, then google for nitriding near you.
  10. Likes Limy Sami, J Grainger liked this post
  11. #8
    Feb 2007
    Aberdeen, UK
    3,992
    1407
    1637
    Recommend you hit up ebay and find a driven tool for a cnc lathe to adapt for your purposes. Not as interesting as making your own, but if you don't have the facilities to do it properly you will at least have a functional milling spindle at the end.
  12. Likes Limy Sami, Mark Rand, J Grainger liked this post
  13. #9
    Jan 2007
    Norfolk, UK
    20,088
    15491
    15842
    A thought on bearings - have you considered magneto bearings ? for their size they'll take some good loads .....here's a taster Magneto Bearings: Magneto Single Row Deep Groove Ball Bearings
  14. Likes J Grainger liked this post
  15. #10
    Oct 2006
    United Kingdom
    278
    129
    6
    Thank you to everyone for the suggestions and discussion, some of the solutions were likely better or more sensible than my intended direction but I wanted to keep the existing design.
    I called a couple of companies today to get a quote for nitride hardening, it was cheaper than expected - usually I tend to think of all that stuff as a higher class of work so it doesn't enter my mind.. seems I should be able to get a few things hardened and still stay within their minimum price too.
  16. Likes Mark Rand, Limy Sami liked this post
  17. #11
    Feb 2010
    ch
    2,596
    220
    342
    plasma nitriding?
  18. Likes J Grainger liked this post
  19. #12
    Apr 2018
    4,711
    2113
    Just two maybe-relevant points ... I put a fair amount of effort roller burnishing on one project. It wasn't as great as Cogsdill says. It was hard to hold size and the finish wasn't that great. For a fairly large number of parts it might be worth the trouble but difficult to get good results on a onesy-twosey project.
    The other point is, there's been a large amount of research into roller bearings. Life span below 58 Rc is poor. Above that is good. So that's another thing to consider ... burnished is never going to be that hard.
  20. Likes J Grainger liked this post
  21. #13
    Jul 2006
    9,618
    2253
    6658
    You want a decent amount of depth for any case hardening, otherwise you can still create a "standing wave" of flexing of the surface, which can fatigue and spall off material fairly quickly when a rolling element is running on it.
    Just a quick guess, but for smaller, light duty direct rolling shafts I'd like a MM or so of ~RC60 hardness. Maybe a bit thinner will work, but I'd be cautious if the case is less than 0.25mm.
  22. Likes J Grainger, CarbideBob liked this post
  23. #14
    Apr 2018
    4,711
    2113
    The other method there is a harder core - say 40 or more - and a thin surface like nitriding that's only a couple thou deep. Some gears are done that way because of distortion, but not usually heavily-loaded ones. Nitriding will get you up to about 70 Rc, which is kinda nice for wear resistance. 4130 is better than 4140 for that.
  24. Likes J Grainger liked this post
  25. #15
    Feb 2010
    ch
    2,596
    220
    342
    why is that? cr/mo is the same.
  26. #16
    Jul 2006
    9,618
    2253
    6658
    Quote Originally Posted by dian View Post
    This isn't (IMHO) a well written article, but it does point out the benefit of lower carbon content in a steel that's to be nitrided:
    Nitriding, Process Methods and Metallurgy | The Monty
    [near the bottom, titled "Alloy steels"]. Basically, lower carbon reduces the deleterious effects of the compound layer.
    Again, I wasn't super-impressed with the writing clarity, so you may want to find further sources to confirm or deny this statement.
  27. Likes J Grainger liked this post
  28. #17
    Jan 2007
    Flushing/Flint, Michigan
    8,984
    484
    7396
    Why not just use a needle bearing sleeve pressed onto the shaft.
    Not enough room?
    Bob
  29. #18
    Feb 2010
    ch
    2,596
    220
    342
    thanks, however my table lists 4130 (1.7218) as hrc 60 max and 4140 (1.7225) as hrc 64 max. similarly i see hv 500 for ck45 and hv 550 for ck60. is that just theory?
    (interstingly grey iron goes up to 62 hrc.)
  30. #19
    Jul 2006
    9,618
    2253
    6658
    If you're speaking of basic response to nitriding, it may be that you can achieve higher hardness, but with a thicker "white layer" with the higher carbon content. But I'm not sure, as I mentioned I'd want to see more references before I trusted anything...
