Okay, so, I'm confused. Not too long ago, I bought some 316 stainless steel strapping from SideCuts:
316 / 316L FULL HARD CRSS .020 X 1-1/25" Stainless Steel Coil - Heat: 606A - Tag: 675251
The product is listed as being "full hard," and having worked with it since receiving it, I can definitely tell you that it is. Now, I'm needing a 1/16 (or thereabouts - 1mm to 1.5mm will work) round stock in either 304 or 316 stainless. However, after doing a good bit of searching, I can't find anyone that sells such a product in a temper other than annealed. What's more, a few shops have material info pages that echo what I see on Wikipedia:
So . . . does hardened 304/316 steel exist, or no? If so, where would I find some small-diameter round stock?
Thanks!
Due to their crystalline structure austenitic steels are not hardenable by heat treatment and are essentially non-magnetic.
Thanks!
