Does your WD-40 look consistent? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #21
    Mar 2009
    5,333
    97
    1013
    The settling action does make for inconsistent results when used with a pump spray bottle. Since the pump is drawing solution from the very bottom of the bottle it
    will spray a higher percentage of the settled out junk. The user has to shake the contents first. I'm not going out to look at the directions but I bet it does not
    say shake first before using.
  2. #22
    Dec 2012
    AUSTRALIA
    2,583
    10
    803
    Lots of petroleum liquids have a settlement of waxes in cold weather .....apparently this is one of the big differences in jet fuel ... doesnt settle wax at 30 below.....Out here we have summer and winter diesel .....summer diesel will block filters in winter with wax crystals.
  3. #23
    Jun 2015
    Minnesota
    445
    8
    159
    Quote Originally Posted by PeteM View Post
    Never would have thought of that, Bill. Think it also makes the photons slippery?
    More seriously, not knowing the ingredients I'd wonder what's being combusted and also if there is a long-term residue in orifices
    I read somewhere awhile back it's mostly Naptha.
    I actually like the stuff. Got a rusty surface needs a little Scotch pad work? The WD does well there. Not a bad metal surface cleaner.
  4. #24
    Mar 2006
    Wisconsin
    1,119
    14
    394
    Quote Originally Posted by rons View Post
    I also use it to clean my tree pole saw blade. I forgot about using it on aluminium. So I guess now it has two uses.
    It's also good for removing glue residue after a stick on label has been peeled off.
  5. #25
    Feb 2005
    Owl's Head, Maine
    2,291
    383
    614
    "Frankly, don't much like the stuff,"
    "I would never buy it again when this stuff runs out."
    "I think they put some kind rust accelerator in it. Shit is garbage."
    "knowledgeable people don't advise its use as a lubricant"
    amen
    might be OK for water displacement and label residue, but for everything else there's better
    -Marty-
  6. #26
    Feb 2014
    Sunny South West Florida, USA
    3,066
    11079
    3453
    Quote Originally Posted by projectnut View Post
    It also makes a cheap and easy cleaner for a motorcycle chain, but some people swear it swells the o-rings in the chain and causes premature failure. 50K+ miles on my bikes and never had a chain fail due to WD-40 that I can tell, so I keep using it.
