saadracing
- Feb 22, 2016
We are manufacturing a double ended stud where the center of the body is smaller than the major diameter of the threads on both ends. Threading one side is not a problem but flipping it over posses the problem. I want to use the 5c collet to help maintain concentricity but cannot grab the threads in the collet, only the body. I am use a thread roller and has a tremendous amount of torque so I am clamping the body with as much force as possible. The only solution was to remove the collet, insert the stud from the rear of the collet and then re-insert the collet back into the lathe and set my clamping force again. Fine for a few studs, but not for what we are trying to achieve as this is a repeat job of 100+pcs. Here are the details of what we have
Doall heavy duty manual lathe model LS17
Manual 5c collet closer
Thread rolling H11 annealed to 8rc
7/16-20 on one end and 11mm x 1.5 on the other
Body is cut to 7/16 pre-rolled diameter with no wrench hex (i.e machine a collet with the threads and thread the stud into it as it will tighten in the collet when roller with no "easy" removal)
Any thoughts would be great. Thanks
