Chrisboon
- Dec 29, 2020
- Johannesburg
Hi
As stated before I am reconditioning a Strands DP.
I have removed and cleaned the gearbox ready for painting.
I now have a problem removing the motor armature.
As can be seen in the attached photos I can either remove the rear drive gears and bearings which i am hesitant to do.
The alternative is removing the front bearing housing. t do this I have to remove the plate in front of it. I can try a bearing puller but am afraid of breaking the cast iron bearing housing.
I am hoping that someone has had a similar problem and can advise me on what I can try to remove the armature.
Any assistance will be appreciated.
Chris
Chris
