Drano eat alum, ok for steel?
Results 1 to 6 of 6
    Jul 2014
    North Carolina
    248
    96
    23
    Default Drano eat alum, ok for steel?
    had a mishap that caught in time to cause any damage, however I have alum galling on my face mill. Doing some search on here and Drano was recommend. They only had the hair type, https://www.lowes.com/pd/Drano-Drano...-oz/1001210174. It's like a water down gel, think dish soap in a bottle. I called around looking for pure lye but no luck.
    Face mill is a ASX Mitsubishi
    Just double checking, this is ok and won't damage my face mill.
    Jul 2005
    Eastern PA
    956
    145
    616
    My local hardware store has cans of flake sodium hydroxide (lye). Nasty stuff but really works on hair, grease and yes, aluminum..............Bob
    Sep 2007
    Woodinville, WA
    1,806
    213
    390
    Strong alkaline base is fine with Steel.
    May 2019
    653
    187
    284
    Lowes where I'm at has this. If you warm the solution it will go much faster.
    Dec 2005
    392
    92
    94
    Easy Off oven cleaner (the original formula in the yellow can) is basically lye and will eat aluminum
  6. Likes Scottl liked this post
    Nov 2013
    Eastern Massachusetts, USA
    4,971
    4912
    4886
    Quote Originally Posted by b2major9th View Post
    I use it to clean clogged files. Takes off everything that isn't steel. The files must be oiled immediately after to prevent flash rust.
    When I use oven cleaner I spray the item and then put it in a plastic box with a tight lid to "soak" without evaporating. It's slower than pure lye so it sometimes needs an hour or two or even overnight.
