Ray Behner
- Mar 27, 2009
- Brunswick Oh USA
OK, not actually drawings. Got to thinking of all the tool holder sizes. AXA thru EA. There's no way I could give dimensions for your size of holder. Therefore, I took pictures explaining what I could. I used a Hiwin carriage and rail, because I have one. I'm sure Thompson or others would work as well. Mine is rated for 8000# in motion and dbl that for static. Plenty strong, so for the AXA for example, a much smaller unit would be sufficient. They are pricey! My holder is a "CA", so I used a 4" x 6" block for the "V" section. I suggest the flanged style carriage. Seems more fitting for this application. As Limy Sami pointed out, you want to have the trigger/sear disengage without any forward/aft movement. That, you'll have to experiment with. Some modifications were made as I went along, so if it looks different than original...it is. I didn't care for the crank handle, so I used a ball and stem.
Decided a return spring on the shaft was overkill. The main spring does just fine. On the smaller holders, you may want to downsize the shaft from 5/8 to 1/2, or even smaller. An "AXA" is pretty puny. My tool holder will accept 1" tooling. If you have an "EA" you may want to go bigger. An "AXA", for sure much smaller.
I used some quality springs that I had in stock. Hdwe store springs are a poor choice for this.
Look thru the McM Carr catalog to get an idea of your size requirements.
If there are any questions whatsoever, I will try my best to answer them. If there are any improvements or suggestions, let's hear them.
100_1458_zpsf4667ca3.jpg Photo by rbehner | Photobucket
