Drill Bit?
Results 1 to 12 of 12
Thread: Drill Bit?
    Oct 2020
    Wisconsin
    40
    8
    Default Drill Bit?
    Hey Guys,
    Please school me on what type of bit is shown in the photo below.
    No tip, so I figured a spiral reamer, but I am an uneducated dolt. I would prefer what the pros have to say. Also, is there any value in them (1/4-inch to 1-inch)?
    Thanks for the insight,
    Greg
    Sep 2015
    Ohio
    1,723
    1148
    1804
    I've heard them called core drills. Might be other names too.
    Oct 2020
    Wisconsin
    40
    8
    Quote Originally Posted by Booze Daily View Post
    Used for coring/drilling what material? Last I heard a core but was used to core concrete. These do not appear to be for that>
    Dec 2017
    Kentucky
    49
    8
    Used to enlarge an existing hole. The extra flute(s) keep the drill from walking.
    Mar 2005
    Indiana
    5,914
    2019
    1972
    Yes they are core drills. They are for enlarging pre-existing holes. Punching through a cast hole for instance to rough it out. Note, the part of the pattern in a casting that creates negative space is called a "core." They use multiple small flutes that are shallow so that the central part of the drill is as thick and stiff as possible.
    Oct 2020
    Wisconsin
    40
    8
    Could they be used on a lathe to achieve a final drilled diameter, following up a smaller hole, or are they primarily for thinner material?
    Jul 2004
    N. GA- 33.992N , -83.72W usa
    3,968
    90
    938
    yes. and a drill bit is a woodworking tool. as in "brace and bit " or ship augur. those are core drills.
    for enlarging existing forged or cast holes.
    Oct 2010
    Oregon
    5,674
    5497
    2153
    Quote Originally Posted by bug_hunter View Post
    Absolutely not limited to thin material. As previously stated, these are intended to make round holes out of rough cast holes in castings. Castings with cored holes are generally not especially thin. However, they do not serve the same purpose as reamers. If you want a typical drilled finish (not very good), core drills will work fine. If your "final" diameter needs to be precise, drill undersize (with any sort of drill) and ream or bore for finish.
    Virginia
    19,308
    7561
    11752
    Yes, they could. Expect a butt-ugly hole finish. Usually.
    Core taper varies. Metals have recommended minimums, but the cores aren't made by a book. They are made by craftsman with their own ideas and judgement. Some tapers even steepen, part way along, and not all are even close to perfectly round.
    A core drill is optimized to not grab, get "sucked-in" and bind in a TAPERED core hole. Like a self-tapping screw does. And which a conventionally tipped helical-twist drill CAN do. DAMHIKT!
    So they have characteristics that makes them akin to a three-way cross-breed between an end-mill, (the tip..) a reamer (the sides can cut if need-be).
    And the Devil. Because most of them are s**t-lousy for attempting to drill a "virgin" hole from scratch. Or just "cannot". More than one core drill type has existed.
    They are meant for a cored hole. They NEED a pre-existing hole. They will manage a taper. But that part they do NOT "need".
    2,040
    357
    312
    Quote Originally Posted by tnmgcarbide View Post
    In the UK a drill bit can be used for drilling metal,just buy the right bit.
  11. Likes Georgineer liked this post
  12. #11
    Virginia
    19,308
    7561
    11752
    Quote Originally Posted by camscan View Post
    And remember which end of the horse to install it on.
    English Horse Bits: Check-out the Different Types of English Horse Bits
    There are SOME things even a very docile horse just won't "put up" with.
  13. #12
    Jul 2004
    3,968
    90
    938
    if you are after a precision hole, a boring bar or endmill . a reamer will just follow the sloppy hole
    and make a pretty, off center hole.
