Drill bits for forged and billet 6061 and or 7075 aluminum
Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    Apr 2021
    Default Drill bits for forged and billet 6061 and or 7075 aluminum
    I have recently been doing some gunsmithing and building from 80% aluminum receivers.
    They are either forged or billet 7075 or 6061 receivers and looking for some recommendations on drill bits that work the best in this type of material.
    TiN coated bits were recommended buy a few folks but wanted to get some input on what others have used to drill clean holes in aluminum.
    Any info would be greatly appreciated.
    Sep 2015
    624
    23
    306
    Bright finish HSS. Sharp and fast
  3. Likes N/A liked this post
    Apr 2011
    Nebraska
    1,446
    2441
    483
    What I do on 80% receivers is to drill a bit under-sized holes (never trust a drill bit to make a round hole or be "accurate") and follow with the proper size reamer. Brand of bit doesn't make much difference this way as long as it's reasonably straight. IMO it's the best way to get good results.
    FWIW
    -Ron
  5. Likes BT Fabrication liked this post
  6. #4
    Jan 2007
    Norfolk, UK
    21,387
    16754
    17467
    Parabolic flute if you're going deep say over 4 xD
    Just my 2 cents YMMV
  7. Likes eKretz, MetalCarnage liked this post
  8. #5
    Apr 2006
    Suffolk, England
    943
    116
    285
    I like TiN coated stub drills on steel, but they suck when drilling aluminium on my small CNC, the swarf seems to bind to them more readily. So I'll echo the recommendation for bright or steam tempered.
  9. Likes Limy Sami liked this post
  10. #6
    May 2010
    Cambridge, MA
    1,834
    82
    1066
    NIST has published material sheets that describe various metals and how they are best machined. The one for aluminum is here: https://materialsdata.nist.gov/bitst...=3&isAllowed=y
    When drilling a material, to get the best possible result you should determine the optimum rake and relief angles for the material and feeds you are using. Insight into these two angles can be gathered from the aforementioned material reports.
    Once you know the angles, take standard HSS metal cutting drill bit and grind the rake and relief into the tip of the drill bit. You will then have an optimum tool for your drilling operation.
  11. #7
    Aug 2007
    Idaho
    2,562
    1105
    1403
    If you are drilling through a steel or annodized guide it will be hard on the drill tips causing burrs on exit especially given the quality of the average drill press these days
  12. #8
    Jan 2014
    Temecula, Ca
    3,431
    1420
    4448
    is this aircraft billet or military grade billet?
    Use a three flute Super Twister. That is the BEST
  13. #9
    Aug 2004
    Virginia
    2,911
    236
    1359
    Yup. Military grade billet is really tough and yells Go! Go! Go! a lot.
  14. Likes Rudd liked this post
  15. #10
    Aug 2008
    Californeeeah
    1,580
    59
    354
    I agree bright finish is what you want. Coatings tend to pick up aluminum.
  16. Likes N/A liked this post
  17. #11
    Apr 2021
    Amazing and good information from all of you and really gives me a different perspective on just what drill bits to use. Most of jigs for these receivers use drill guides so I had never toyed with the idea of drilling undersized and reaming to correct size.
  18. #12
    Nov 2005
    Illinois
    2,297
    247
    2229
    We sell these Nucon HSS drills. Lots of great feedback. Very affordable as well. We also have them in ZRN coating.
    Tool Holders, Collets and Machine Accessories NUCON Drills - MariTool
  19. Likes Chris Attebery liked this post
  20. #13
    Guest Guest
    Quote Originally Posted by Spruewell View Post
    This, there is no need to spend money on fancy drills working in 6061 or 7075 unless you have an excessive depth to diameter ratio. Unless of course you are trying to machine crappy Chinese 6061, then all bets are off.
    P.S. Refrain from buzz words like billet. I can't believe it took till post #8 for a comment.
  21. #14
    Jan 2005
    Houston
    7,134
    1330
    4140
    Gunsmithing, Aircraft piloting. Horse riding. Video game playing. Drinking, especially in nightclubs. Mainlining heroin. All activities in which I'm dead thankful I never took an interest.
  22. #15
    Guest Guest
    Quote Originally Posted by GregSY View Post
    Horse riding isn't bad, it just isn't as easy as the experts make it look.
  23. #16
    Mar 2005
    Indiana
    6,276
    2217
    2272
    Quote Originally Posted by Dualkit View Post
    ×3 on this, with an addendum. Don't spend money on fancy drills unless you have a high quantity of parts to do. It's not worth it. The benefit is small and it takes a lot of parts to add up to anything relevant in terms of the time spent. A plain bright drill or even black oxided drill will work just fine for one or two parts.
    I've just been working on about 6 or 7 of these 80% lowers for a friend of a friend, using plain old black oxide drills. No problems whatsoever. Absolutely do use a reamer for things like the pin holes, and WD40 for cutting oil works great.
  24. Likes MetalCarnage liked this post
  25. #17
    Feb 2004
    peekskill, NY
    27,283
    6353
    Lookmif it's a forged billet part he needs to use a forged, billet drill. Buncha novices....
  26. Likes 310 Guy, Rudd, BT Fabrication, tdmidget liked this post
  27. #18
    Apr 2021
    Quote Originally Posted by jim rozen View Post
    Just purchased the forged, billet drill. Thanks for moving me out of novice territory and into the RozenZone ; )
  28. #19
    Jan 2007
    Norfolk, UK
    21,387
    16754
    17467
    Quote Originally Posted by fmari --MariTool- View Post
    And made in the USA I see, ..big
  29. #20
    Jul 2007
    Brookfield, WI
    687
    959
    614
    I think Oscar Wilde said "I'll try anything once except folk dancing and incest."
