For a product I'm prototyping I need to make some approx. 0.5" long pieces of thin wall stainless steel hypodermic tubing with a small hole drilled in the wall at one end.
Probably I will use .058" OD,.05" ID tubing. The hole needs to be about 0.04" in one wall (about 1 mm). The hole does not need to be extremely accurate as long as it has a large enough opening. The tubes are to carry static air pressure air to pressure sensors.
What would be be easiest and and fastest way to drill the holes? What type of drill? Drill speed? How to clamp the tubing?
