Drill holes in thing stainles steel hypodermic tubing
Results 1 to 14 of 14
    Jun 2019
    CANADA
    British Columbia
    Default Drill holes in thing stainles steel hypodermic tubing
    For a product I'm prototyping I need to make some approx. 0.5" long pieces of thin wall stainless steel hypodermic tubing with a small hole drilled in the wall at one end.
    Probably I will use .058" OD,.05" ID tubing. The hole needs to be about 0.04" in one wall (about 1 mm). The hole does not need to be extremely accurate as long as it has a large enough opening. The tubes are to carry static air pressure air to pressure sensors.
    What would be be easiest and and fastest way to drill the holes? What type of drill? Drill speed? How to clamp the tubing?
    Feb 2007
    St. George, Utah
    775
    333
    479
    How about EDM? I suppose you could plunge a small center-cutting endmill/engraver as well. With EDM there is no risk of collapsing the tube with down pressure. If you don't have access to a sinker EDM, you could probably get a tap-burner with a wire electrode to work too.
  3. Likes MrWhoopee, Billtodd, TDegenhart, Ziggy2 liked this post
    Nov 2018
    Michigan
    204
    95
    110
    +1 For EDM. I used to work making machines for small, precise EDM holes. Last I knew, they were still in business, but ol' George has gotta be coming up on 70 now.
    If you had an interesting project, he would work on existing parts. How many do you need?
    Dec 2008
    Vt USA
    6,607
    714
    2236
    You could think about a slot rather than a round hole.
    A small radius slitting saw sort of cutting tool.
    Apr 2019
    AUSTRALIA
    15
    10
    How many units do you need?
    Feb 2014
    Sunny South West Florida, USA
    2,522
    10071
    2960
    I'd use a crazydrill pilot from mikron... They excel at drilling into rounds without walking... A cheaper alternative would be a circuitboard drill from kyocera (or tons of other manufacturers, they're just the ones I'm most familiar with), or finally, MA Ford should have a 305 series drill in your size, they'll be the cheapest option for sure, but they may want a spot drill to keep from walking, where the other drills probably would be fine without a spot.
    Feb 2009
    Colchester UK (where the lathes used to be made)
    1,890
    1299
    547
    might be worth slipping a sacrificial copper wire down the tube to prevent distortion.
  9. #8
    Aug 2012
    California, Central Coast
    3,051
    2114
    1172
    Buddy of mine just drilled some .020 holes through .048? stainless hypodermic tube. He got a .020 four flute center cutting end mill and it did great. He said the cutter came from harvey tool.
  10. Likes michiganbuck, rcoope liked this post
  11. #9
    Oct 2005
    14,087
    Might be nice to know what machinery & experience you have at your disposal.
    Suggestions are a flyin' and you could be hoping to use a cordless dewalt and
    hold the tubing in your fingers....
  12. #10
    Aug 2012
    3,051
    2114
    1172
    I dont know what machine my buddy has at his work. He did say it has a 4000 rpm max speed and the harvey guys sugested 16000 rpm for the .020 cutter. They gave info on how to make his rpm work. I will see him tomorrow and will ask what machine he used.
  13. #11
    Jun 2009
    Michigan, USA
    2,155
    3294
    1705
    We used to edm lots of holes of about .005 diameter with a wire edm. Not the wire edm's that you see in many shops but one that feeds a wire through a ceramic guide and the end of the wire burns the hole. My dad was instrumental in developing the technology in the 60's. The holes were in diesel spray tips.
  14. #12
    Feb 2014
    2,522
    10071
    2960
    Quote Originally Posted by Big B View Post
    If you're referring to what I think you're referring to, those are EDM Drills, "hole poppers" in common parlance.
  15. #13
    Jan 2007
    Flushing/Flint, Michigan
    7,427
    366
    6216
    For a prototype and one or two parts I'd go to a EDM house with the above mentioned.
    This process is very slow to say the least but a quick and easy setup.
    The hole takes up a significant amount of the tube size.
    Drilling is faster but you will have to build a part nest and that fixture is expensive in one offs.
    EDM dills exert no pressure so part holding is simple.
    The dia of the hole to the stock bothers me. If a .015 hole I'd be just drill it. Drilling also leaves a burr inside that I'm not sure you thought about.
    Light pecking a ballnose endmill either full or as a finish size pass can reduce that burr but some will still be there.
    Is it large enough or low speed enough that flow rate is not a problem?
    Bob
  16. #14
    Oct 2013
    st,louis mo
    651
    335
    It sounds like all you really need is an OPENING in the wall of the tube. How about getting one of those cheese cutters that cut with a wire. Use medium diamond lapping paste and you should be able to RUB a hole in the side of the tube in no time.Clamp the tube in a very small vise with part of tube sticking out of the side. Use the side of the vise as your saw wire guide. Edwin Dirnbeck
