Drill methods and bits for structural beams
Results 1 to 15 of 15
    Jun 2019
    5
    Default Drill methods and bits for structural beams
    What type/brand drill bits do you guys use to drill holes in structural beams (wide flange W type)?
    I would normally put them onto milling machine, but this time they are way too long, so mag drill is proabbly a way to go.
    Aug 2005
    Tucson AZ
    6,749
    10859
    3243
    Furnish the supplier a drawing and let them punch them.
    Mar 2009
    Eureka, CA
    4,407
    1042
    1780
    When I did that chore I used a mag base drill with annular cutters..worked very well.
    Stuart
  4. Likes Limy Sami, Gordon Heaton, ernieflash liked this post
    Jun 2019
    5
    Quote Originally Posted by tdmidget View Post
    I wish. Prints specifically call for drilled holes. This customer does not accept punching and thermal cutting
    Sep 2015
    622
    23
    305
    I saw this a couple years ago.
    How to Sharpen Drill Bits for Structural Steel - Ocean Rejuvenator Ocean Penetrator - YouTube
    It looks a bit like a brad point drill
    Mar 2011
    Kansas
    1,004
    122
    297
    Quote Originally Posted by Ezmetal71 View Post
    Then have the supplier drill them instead on their beam line. Ours has no problem doing that, if yours can't drill them, find a new one.
  8. Likes Limy Sami, digger doug liked this post
  9. #7
    Dec 2012
    Se Ma USA
    2,249
    180
    1225
    TILAN COBALT .5" drill with just air blowing on it. I got about 1000 holes with 1 bit when I made my cantilever stock racks. Drilled in my VMC. Bit was still good when I was done. I used a mag drill when I built my bridge crane system. Splice plates had a fussy hole pattern and I made a .75" steel template to drill through. Twist drill bits in mag drills tend to drift away from the base because of the play in the smaller machines. Template kept the hole pattern spot on.
  10. #8
    Oct 2012
    Lansdale, PA
    121
    29
    What Atomarc said. Annular cutters in a mag drill are made for that work. No need to reinvent the wheel.
    I have used them in for many holes. They work fast and cut nice round holes.
  11. Likes cyanidekid liked this post
  12. #9
    Jan 2007
    wales.uk
    1,790
    386
    411
    I’ve seen our local suppliers beam processing machine, it can drill, punch mill, even bend tounges, oddly it’s not that expensive, adds about 20%, much more fun than a rotabroach, the next course of action
    Mark
  13. #10
    Oct 2014
    Maine
    1,314
    261
    628
    There is a significant hit to fatigue properties with thermal cutting. If you want to punch the holes, the usual routine is to subpunch and ream.
    For drilling, either annular cutters or have someone with a beam line do it.
  14. #11
    Jan 2012
    Florida
    221
    272
    83
    if the customer does not allow punched holes better check they may not allow saw cut ,may require mill cutting of ends .Most Heavy columns (14x 500)require mill ends for load bearing.
    just my two cents
  15. #12
    Jun 2019
    5
    Thanks guys! Looks like a mag drill and annular cutters is the way to go, unless I find a steel supplier who offers beam processing
  16. #13
    Jul 2006
    Hillsboro, New Hampshire
    13,692
    3003
    9133
    Be careful with cheaper mag drills - they frequently don't have good "Z" slide control (sloppy fit), if you do heavy cuts they may shift the hole even with a strong magnet.
  17. #14
    Jul 2007
    Missoula Mt
    1,399
    62
    676
    I make a drill pattern from 1/2 plate and clamp it on to the beam, check twice and use a mag drill and hhs bit...Phil
  18. #15
    Jan 2019
    Tennessee
    733
    217
    218
    allied makes inserts for structural shapes. They run a slower rpm and feed than the ones for milling machines. Beams are not rigid. Sounds like hole quality is issue, so allied thin wall structural inserts are the way to go. Clean hole, a little slow (compared to helix gen3 or even spade gen 2 inserts.
    Our drill line limits out at 1500 rpm, and rarely do I need to detune speeds to accommodate their recommendations. Gen 3 carbides are detuned from 13/16 and under for rpm limits of our machine.
    Mag drill with hougans is for forgotten or changed holes, back in the dark ages this is how all beams were done. Then we got punch lines, drill lines, and moved to coping (plasma) lines. Little secret, you can drill a hole faster than you can burn a hole 9 out of 10 times- even before clean up times.
    never heard of milled beam ends, ever.
