Drillbit stuck in rod
Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Sep 2019
    Alabama
    19
    Lightbulb Drillbit stuck in rod
    Hello! I was drilling a 0.8mm hole in a steel rod, and the drill bit broke inside of the hole when i came through. Any idea on how I could possibly get the drill bit out of the hole? I have tried pulling it out with a tweezer but there isn’t material enough to get a hold of it. I also tried to force it out with another drillbit infront of a hammer, but they all broke.
    Here’s a picture of the rod and the bit stuck in it: Imgur: The magic of the Internet
    Jan 2014
    Temecula, Ca
    3,276
    1396
    4258
    Really? How much do you want to spend to save $.30 worth of material?
    Sep 2019
    Alabama
    19
    The steel rod have been machined with multiple holes from the other side that connect to this (final) hole. Remaking everything from scratch will be much work, so I really need to get the bit out..
    Jul 2006
    Arizona
    4,712
    18688
    4558
    Quote Originally Posted by Drilldept View Post
    EDM the drill bit out or remake the part.
  5. Likes yardbird, MrWhoopee liked this post
    Feb 2014
    FL
    3,419
    11685
    3916
    Is it a carbide drill?
    Get after it with a hammer and a small piece of steel. Break it up into little chunks.
    If it's HSS, get a tiny endmill, peck it out. It's slow, but it works. Make sure to blow the hole out frequently to get the swarf out.
    Sep 2019
    Alabama
    19
    It’s HSS. Can I drill it out with a larger (1.5mm HSS) bit?
    Mar 2006
    PHILIPPINES
    2,663
    686
    1036
    Perhaps take it to your local machine shop?
  9. #8
    Nov 2013
    Utah
    4,876
    1289
    2755
    Actually it works better if you try using a Drill made out of Marshmallow.
    Since you broke it on break through.....Endmill the break out with a .8mm carbide Tool, until you're into the hole, then punch it out with a punch.
    R
    Careful selecting a username around here, yours implies that you might know the very basics of Drilling and Drills.
  10. Likes eKretz liked this post
  11. #9
    Mar 2011
    Geneva Illinois USA
    6,439
    2817
    2521
    You could cut it out with a 4 flute carbide center cutting end mill. I have done that but you have to be very careful or the end mill will shatter.
    Tom
  12. #10
    Aug 2006
    N.W. Ark.
    411
    241
    71
    if the length of the piece is not critical put in lathe and shave off what you need to grab the bit with pliers or vise grip and rotate to the left back the bit out
  13. Likes tech610 liked this post
  14. #11
    Nov 2014
    Florida
    4,511
    1730
    2161
    R
    Maybe he meant Drilderp..?
  15. Likes TeachMePlease, litlerob1 liked this post
  16. #12
    Oct 2016
    Florida
    355
    820
    229
    I would grind off the broken drill flush to the part.
    Use a smaller carbide drill and gently carefully drill down through the center of the broken drill, use Tap magic pro 3 lubricant and clear the chips frequently.
    Clear away cut metal frequently
    Absolute minimum pressure
    Take an hour to do it
    After you bore down through it will almost fall out
    Don't make another part like this the same was, you need to spend more time figuring out what is wrong that you are doing
    Sorry you have to do metric
  17. #13
    Mar 2005
    Indiana
    4,751
    1254
    1184
    I'm with Rob. If it snapped while breaking through just take a small punch and knock it out backwards. Most of the hole is already there, should be easy and the drill should only be tight at the exit point. Just don't use another drill bit as a punch... Could help to mount the punch in an endmill holder or drill chuck to help keep alignment, then use the machine to align it over the hole and push the broken drill out.
  18. #14
    Oct 2005
    17,683
    Could it be, stuck because of lack of proper lÜÜB ?
    Might be welded in place, and making the part worthless.
    What material ?
    What machine did you drill this on ?
  19. #15
    Jan 2005
    Victoria, Texas, USA
    4,247
    2561
    1112
    I have some 1/32" drill bits here if you want to try it again. There are no good to me...and too small to see what I'm doing.
  20. Likes NC Rick liked this post
  21. #16
    Mar 2011
    Geneva Illinois USA
    6,439
    2817
    2521
    Quote Originally Posted by Pathogen View Post
    Use a flat end end mill. The drill point will cause the drill to wander and break.
    Tom
  22. Likes JohnEvans liked this post
  23. #17
    Virginia
    31,210
    7561
    9798
    Like it or not MORE work, yet to get it out and then.. the rod is buggered as well?
    You don't HAVE any of the more reliable means that do not also near-as-dammit ASSURE you will f**k-up the rod in the effort ANYWAY. Don't HAVE the experience, dexterity, machine-tools, nor tooling to improve chances of success.
    Or it would have been OUT, already, drills being dead-easy compared to bustid TAPS!
    QED
    Spark erosion / EDM, specifically - which one usually hires done.
    Can't get that done? Costs too much? Make a new rod and be more CAREFUL.
    If you were not already aware of it, "start over" - small parts more than massive castings, of course - is the preferred professional "cheat", if only because we have the most accurate sense of what it will cost in material and TIME, can plan accordingly and "JFDI" to plan.
    Shit happens.
    Life is always too short and deadlines for delivery always too close to roll-dice on praying, hoping, wishing, whining, masturbating, or other general fucking about at solutions we cannot implement even if we were willing.
  24. Likes NC Rick liked this post
  25. #18
    Sep 2019
    Alabama
    19
    What material ?
    QT 4340 chromoly steel. I was using a bench drillpress.
  26. #19
    Sep 2009
    Phoenix,AZ
    1,861
    2866
    483
    Recipe for failure ! Bench DP ,a sensitive drill press would have been still bad enough ,but much better.I have drilled 1/4MM holes in 1018 using my Hamilton sensitive DP CAREFULLY !
  27. #20
    Oct 2005
    17,683
    RPM ?
    coolant ?
    Peck drill ?
    What is your experience level ?
  28. Likes g-coder05 liked this post
