Drilling Holes In Carbon Steel
Page 1 of 2 12 LastLast
Results 1 to 20 of 27
    Feb 2020
    New York
    6
    Default Drilling Holes In Carbon Steel
    Hi,
    I am looking for the most efficient way to drill approx 65 - 7/8" dia holes in flat, 1 1/2" thk carbon steel plate on a CNC mill. We currently use a high speed drill for this operation which seems time consuming with the pilot holes, pecking, and slow feed drill rate.
    We have heard the Sumitomo 3xd replaceable thru coolant w/ 7/8" dia drill tip inserts would work best for this operation.
    Is this the way to go? Other suggestions?
    Jul 2010
    northern illinois
    96
    14
    24
    Jun 2012
    Eastern PA
    1,043
    308
    477
    Just don't use a High-speed drill at S2500 and F4 (IPM) with no coolant, like I accidentally did yesterday.....
    Jul 2013
    atlanta, ga
    106
    12
    56
    Annular cutter? Always my go to for holes <1/2”. Put it in a 3/4” collet or tool holder.
    Jan 2007
    Norfolk, UK
    19,908
    15348
    15624
    What milling machine - cos some tools need less speed but more power, torque and push than some CNCs can deliver.
    Oct 2005
    17,861
    Might be a wee bit nicer if you put some prices on your suggestions....just sayin'
    Feb 2020
    New York
    6
    Haas Mill VF 8 / 30 Hp / 7500 RPM
    Feb 2020
    New York
    6
    Would you consider these similar to the Sumitomo 3xd replaceable thru coolant drill tip inserts?
    Dec 2012
    Se Ma USA
    1,747
    139
    955
    What happens when the slug stays in the cutter? That would be my concern.
    Jun 2019
    430
    142
    384
    I've never used any Sumitomo drills, but I could also suggest either a Sandvik CoroDrill 870 or an Iscar Sumocham. If you want to increase your throughput they also make one with a 3 flute design that I haven't gotten to use yet, but have been looking for an excuse to get.
  11. #11
    Jul 2010
    northern illinois
    96
    14
    24
    Quote Originally Posted by fstdril View Post
    with out knowing which sumo line you are referring too, both of the links i provided are products with through coolant drill bodies
  12. #12
    Feb 2020
    New York
    6
    Quote Originally Posted by CAMasochism View Post
    Sounds good, Thank you. Ever had any issues with the tips breaking midway through a hole?
  13. #13
    May 2011
    New Jersey
    2,536
    228
    1363
    Is your mill thru coolant capable?
  14. #14
    Feb 2020
    New York
    6
    Yes, our mill is thru coolant capable
  15. #15
    Jun 2019
    430
    142
    384
    So far only when an operator isn't paying attention to their inserts or when through spindle coolant isn't available. Once you get your speed and feed dialed in with either of those drills they have great life. The Iscar 2 flute Sumocham drills come in a fairly wide variety of geometry designs, so if one of them isn't quite working you can try another.
  16. #16
    Jun 2012
    Michigan
    5,208
    4788
    3150
    Never had any luck with the Iscar Chamdrills I'd stay away from those, they just haven't worked like they claim, at least for me.
    However the Sandvik 870 drills are really, really good! And don't forget to look at Kennametal etc.. each big name brand has their own replaceable tip drill and they are all pretty much similar in performance.
    Do you know the exact type of steel you're drilling? Carbon steel plate can mean a million different kinds of steels.
  17. #17
    Jun 2015
    Minnesota
    535
    9
    187
    Straight shank, 3/4 or 1/2" shank S&D 135 deg HSCO 7/8" drill - 442 RPM 7.2 ipm. 7/8" does not need a pre-drill. G73 high speed peck to eliminate any long errant chips. Try 3-5 pecks total to start.
    Drill time - 0.1 clearance plain - 0.18 tip length plus over-drill - 1 1/2" stock - 1.9" cut length X 65 = 123.5" LOC / 7.2 ipm = 17 minutes.
    4 pecks costing you maybe 0.4" X 65 = 26" / 7 = 3 3/4 minutes.
    Let's call it 21 minutes.
    Chamfer both sides with long neck 1/2 carbide DA cutter from Harvey or the likes. (3.1415 X 0.375 tool path D) +(0.2 lead in lead/out) X 65 X 2 = 179 LOC / 30 ipm = 6 minutes.
    In the cut time for job around 28-30 minutes.
    In short, if you had just loaded a drill on hand and started drilling instead of posting here you would already be done and on to the next job.
    With a rigid setup and proper coolant concentration the drill should make it through the whole job without a problem.
    If this is a repeat job and you have no drill yet on hand then by all means, go the high route. But remember the basics is just about a half an hour w/ 2 sided chamfering.
    Last edited by 13engines; 02-21-2020 at 08:33 AM. Reason: large brain fart on chamfer equation. material stated improved times
  18. #18
    Feb 2020
    New York
    6
    Material is SA-516 70 Normalized plate
  19. #19
    Oct 2005
    17,861
    Qty (18) post's in, an then you announce this little fact ?
    Why not in post #1 ?
  20. Likes Mtndew, Steven-Canada liked this post
  21. #20
    Jul 2004
    N. GA- 33.992N , -83.72W usa
    3,841
    71
    895
    isn't all steel carbon steel?
