Drilling holes with a jig bore
Results 1 to 10 of 10
    Mar 2011
    Denver, CO USA
    11,691
    45
    5323
    Default Drilling holes with a jig bore
    The cost of a jig bore is low compares to a good drill press.
    For small, sub 1/2” holes is a jig bore suitable?
    In particular for small holes, sub 1/4 is it a good mix between a sensitive drill and a drill press?
    I can always buy a big cheap beater drill press for hogging holes, but the cost for a good precision press is well above a solid used bore.
    Any how, the summary is...
    If I get a small jig bore will I also need a really good small sensitive drill pres.
    Apr 2004
    Milwaukee,WI
    1,064
    8664
    766
    Why don't you get a cnc mill? It will do everything.
    Mar 2011
    Denver, CO USA
    11,691
    45
    5323
    Quote Originally Posted by converterking View Post
    Not really..quick holes in un fixed or lightly retained parts aren’t good on a CNC.
    The 10 second hole becomes a two minute process.
    Jul 2004
    Houston, TX USA
    27,995
    I'd hardly refer to my 15,000 Lb Jig Bore as sensitive, but it was enough so to not break 3/32 tip of center drill in 364 spots that I later turned into grooves with a 3/32 carbide ball end mill.
    This repair job is in service
    Apr 2004
    Milwaukee,WI
    1,064
    8664
    766
    I have a cnc bed mill that still has a manual quill. I don't have manual mills anymore, the bedmill does everything that I don't want to run in a vmc.
    Apr 2006
    Manchester, England
    7,326
    939
    4305
    Jig borers are very accurate but slow to operate. For bog standard drilling work you want a good drill press.
    I suppose it depends if you're tinkering around in your own time or trying to make some money. If your shop is a hobby style shop get a jig borer, if you're working to make a living get a drill press.
    Just my opinion.
    Regards Tyrone.
    Dec 2004
    San Antonio, Texas
    135
    174
    Answer is yes. I've drilled many small holes on jig bores and bridgeports. For really tiny drills I like to use a finger chuck.
  8. Likes WHHJR liked this post
  9. #8
    Dec 2005
    New Jersey
    3,874
    280
    463
    I used to use my BP for all drilling. Sold the 1/2" DP. But a few months ago I found a Burgmaster 6 spindle Turret Drill press. Its the smallest one, Max drill size is 1/4, and now use it every chance I can. Position accuracy is up to operator, but really handy for a string of holes, then countersink , Tap.
  10. #9
    Mar 2005
    Kansas
    6,895
    373
    3024
    I have a Moore #3 that would make a dandy small drill press. I think my largest chuck is 1/2" capacity. In some ways its better than a drill press, as the counterbalanced head is much easier to move up and down than the table on a drill press.
    The biggest drawback of a Moore is the tool retention method prohibits reversing the spindle. Taping would require a tapping head. The weight could be another drawback, but if its within the capacity of your forklift weight is immaterial.
  11. #10
    Mar 2011
    Denver, CO USA
    11,691
    45
    5323
    Quote Originally Posted by gbent View Post
    Nothing a big drill press wouldn’t bridge.
    I keep looking at the “sensitive drill presses” but a 1-1/2 Moore is the same price and has a hell of a lot more capabilities.
