Drilling larger holes in steel
Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Aug 2021
    New Hampshire
    Default Drilling larger holes in steel
    I am brand new to this forum, retired and have a woodworking and metal working shop for my own use. I am at best an amateur hack. My question that I posed to different people seems to get different answers so I'm just trying to sort it out. Specifically I want to drill 1 to 1.5 inch holes in steel plates using drill bits with reduced 1/2 inch shanks. I have a Jet 2HP 20 inch variable speed drill press. My question is about the chuck. If I use a Jacob's 20N Super Ball Bearing Chuck, the maximum drill capacity is 1 in. But can I use a 1.5 inch drill bit diameter with 1/2 inch shank in such Chuck? Or will I get slippage because of the excess torque exceeding the capacity of the chuck? Also I asked a supposed expert at MSCDirect this question and he said run it at a slower speed so the torque would be less which makes no sense to me as I thought torque increases at lower speed. Your feedback would be greatly appreciated.
    Dec 2012
    AUSTRALIA
    5,057
    33
    1829
    Forget your chinee rubbish.......to drill 2" holes in steel with a standard MT drill,all you need is a ratchet drill driver ,and a chain pulldown.......you cannot believe how effective the 150 year drives are until you use one.
    Dec 2012
    Se Ma USA
    2,317
    186
    1273
    Find a way to use an annular cutter. Should be much easier on you and machine.
    Virginia
    21,988
    7561
    12673
    What Scruffy said.
    "Relative" example for conventional "Helical twist drill":
    Capacity 3" in Cast Iron, 2 1/2" in steel.
    What does that?
    Four thousand four hundred pounds avoir and seven horsepower driving a # 5 Morse taper through a PIV Werner-Reimers metallic belt varidrive and reduction gears. Power downfeed alone has about the same power budget as the whole mini-drill press owns.
    Seems like a lot of power? An Allied VP was kind enough to assess it for me as to use of "spade"drills with high-pressure coolant. No Joy. About an inch and quarter and it hits the wall.
    I own a lot of annular cutters now!
    Because.. a Hougen or Milwaukee annular may be, and usually ARE, driven with a portable, battery or corded, "mag base" drill.
    But "not only".
    Hougen Annular Cutters for Mag Drills, Sheet Metal, Machining and Industrial Applications
    GEOMETRY is in play.
    Twist drill has to convert 100% of the metal in the hole to loose chips.
    So does a spade drill, just faster. Similar equation comparing helical in wood to an Irwin-pattern "Speedbore".
    Mass goes up on a multiple as the diameter gets larger. Power required - both twist and feed - climbs with it. Non-linear equation.
    An "annular" or trepanning process only has to chew-up a narrow cylindrical "wall". A tube shape, IOW. The rest of the "slug" is not disturbed
    Bigger the hole? BIGGER the difference in favour of NOT arguing with 100% of the metal.
    Deeper slug cavity, otherwise same plan as the "holesaw" in wood.
    And/or metal, you but buy the GOOD ones.
    Annular is too raggedy? Reamers exist, and they do NOT need massive power budgets.
    Page Two:
    Helicals are a Royal Bitch Kitty on "breakout", off-side. Most especially when the material is thinner than the depth of their point.
    Annulars are MUCH nicer on thin material. Apron on a stainless sink top wants a hole for an extra item? You got it. No fuss. Not even a lot of muss.
    Oct 2009
    Olympia, Wa
    801
    345
    256
    I have a cheap 1" drill bit with a 1/2" shank. It will drill steel plate just fine, but 1.5" may be too much for a 1/2" shank. I would also recommend an annular cutter, or a MT shank drill. What is the lowest speed on your drill press?
    Feb 2007
    Ontario, Canada
    165
    333
    24
    I was going to try an annular cutter but my jobber said they were for magnetic drill only. Something about getting the core out of the drill after the hole was made. Is there a problem getting the core out sometimes?
    Sep 2006
    SW Wisconsin
    769
    261
    290
    Quote Originally Posted by DJ2 View Post
    It's always worked for me. I use a needle nose plier to pull out the core if it does not fall out. Worst case you pull the cutter and knock it out through the back.
    Ed.
  8. Likes Ray Behner liked this post
  9. #8
    Jul 2011
    Brusly, LA
    917
    23
    376
    I have a 20" wilton dp, 2hp. I have drilled 1.25" holes with it BUT
    I use a mt3 taper shank drill, well sharpened bit, speed as low as it will go, and even then its on a vfd turning about half speed of that. My dp weight is abot 700 lbs, it has the hp but will chatter if I go to fast, which I think will be your limitation too.
    Use an annular cutter or a hole saw, they work really well.
  10. #9
    Apr 2005
    Brandon, MS
    903
    136
    208
    Find a different jobber. And then get the new guy to sell you an adapter that will hold an annular cutter in your drill press. The adapter will increase your tool length. Keep the coolant poured on it and you should be fine.
  11. Likes DJ2 liked this post
  12. #10
    Dec 2008
    IL/WI border
    3,554
    1291
    1120
    APT Multi-Tool set will work for you. Try to find one that can get inserted directly into the drill spindle taper where your chuck shank goes.
  13. Likes crazygoat, gbent liked this post
  14. #11
    Virginia
    21,988
    7561
    12673
    The SHANKS he stocks surely are. One can get adaptors, but the Hougen link has several shank types already. Buy adaptor(s) and the mag drill ones IF you will ALSO have the mag drill.
    Nowt to do with mag drill or such. Slugger has no klew what is pushing it, nor brains enough to act differently if it did have.
    Universal and not uncommon that a core needs persuasion.
    There are side slots, back holes, etc etc to get them out. Not a show-stopper at all - minor nuisance, now and then, rather.
    Or they would not be so popular.
    There is lore to it. Different techniques to get used to.
    As with woodworking, where I have many "types" of hole-making goods, there is no "one and only". Most situations, there is only a ranking by preferable vs less-so.
    Best machine-tools on-planet can't make wrong or s**t tooling look good.
    Best tooling can make even a lousy machine-tool work OK, and if the craftsman minding it is experienced? Even right heroic.
    Not new news, is that?
  15. Likes DJ2 liked this post
  16. #12
    Mar 2016
    Alabama
    412
    478
    133
    1.5" is a lot for such a machine. What is the spindle taper?
  17. #13
    Mar 2005
    Kansas
    8,776
    630
    4506
    Divide 320 by the lowest speed on your drill press. This is about the largest hole size you will successfully drill rillo a hole this large, but trying a hole larger than this will end quickly in frustration. This applies to annular cutters.
    Another way of determining the largest hole would be to find the largest size Morse Taper standard drill that will fit your spindle taper. Anytime the drill size gets above 1 1/2 times the shank diameter things start to get sketchy.
  18. #14
    Jun 2012
    Michigan
    14,336
    4885
    5182
    The drill point web takes a lot of pressure so a pre-drill and drilling in incremental diameters can help.
    Taking too much is tough to do out of a drill chuck or with a belt drive machine..
    Running at a slow speed is best for larger drills, and can provide more torque in a gear machine but in a belt machine, the belt slippage and chuck holding capacity can limit the torque.
    Your DP looks heavy-duty and gets down to 65 RPM, still, a tang drill likely would be better for large-size drilling.
  19. Likes eKretz liked this post
  20. #15
    Oct 2005
    22,768
    Quote Originally Posted by Herbettehunter View Post
    When you remove the chuck, what do you see ?
  21. #16
    Feb 2011
    BFE Nevada/San Marcos Tx
    3,334
    3294
    2082
    Get a mag drill! I purchased one a couple months back and the only thing I regret is not buying one years ago.
  22. #17
    Jan 2016
    New York
    352
    7
    96
    Quote Originally Posted by Blazemaster View Post
    If your determined, first drill smaller holes to reduce the force required. Your always matching the job with your equipment in the shop. Even so 1/2" shank is skimpy with a 1 1/2" drill. Expect the drill to slip in the chuck. If your OK with that, go for it! The drill should run about 160 RPM for 1 1/2" dia. and the 240 RPM for the 1" dia.
    Roger
  23. #18
    Feb 2020
    Maryland
    300
    115
    Put the bit in an indexer and use a carbide mill to make the shank triangular. That won't slip in the chuck.
  24. #19
    Jan 2002
    West Coast, USA
    9,345
    613
    6819
    As others have said, use an annular cutter. Cleaner cuts, lower HP required, and far less chance of grabbing your workpiece or vibrating the drill holder out of its (I presume for most Jet 20s DP's) 3MT shank holder.
    Use cutting oil - black sulfurized pipe threading oil from Home Depot etc. is fine for steel and readily available.
    If your drill press has a 3MT shank, you might invest in a cheap 3MT to ER32 collet adapter. Most annular cutters have a 3/4" holding portion that will fit in a 3/4" ER32 collet. You could also try your 1" Albrecht chuck, but it's not as good a solution IMO.
    Next thing to consider is how to pilot the annular cutter. Either drill a small pilot hole for the standard annular cutter pilot (which you might want to spring load) or make an outside guide - even plywood with a 2" or so hole (whatever you're doing) can work. You can also easily make up a pilot that will serve as a knockout for the center bit. Remove cutter from collet, punch out the center bit, put cutter and pilot back in the collet and drill another hole.
    While you're at it, make sure you have a good way to secure your work.
  25. #20
    Jun 2014
    New Jersey
    468
    471
    242
    since this is a machinist forum you are hearing about using an annular cutter, which is good advice.
    But how accurate a hole do you need? If you are just punching holes, even a bimetal hole saw will produce an easier, quicker hole than a twist drill. and your drill press won't complain.
    But the hole is not perfect. Neither is the annular compared to a boring head. But it's like a volkswagen to a mercedes, to a ferarri.
    if the hole just needs to be a good hole, a bimetal hole saw will do. Just put a piece of wood under the metal.
