Drilling out a carbide bit??? S#@t F@*K
Results 1 to 14 of 14
    May 2017
    Missouri
    24
    22
    Default Drilling out a carbide bit??? S#@t [email protected]*K
    Drilling a 0.046" 2-flute carbide bit into an unobtanium component. Broke off as it just started to exit 1/4" material.
    Hard to explain, but there is a hood over the exit hole, so I cant punch it back out in reverse.
    Is there some kind of 'super' drill-bit that I can drill through the carbide bit/plug? Largest bit I can use, largest ID I can go to, is 0.050"
    I have scoured the interweb, and came up empty handed. EDM wont work because of the overhang/hood.
    Jan 2001
    Minnesota
    2,175
    69
    1241
    EDM should be able to sink an electrode anywhere you got a drill in. Personally, I just take a punch (core pin or ejector pin smaller than .046 should work)and try to bust up the brittle carbide. Just keep tapping away with a small hammer and punch, and blowing the chips out of the hole with air. Try not to booger up the sides of the hole too much with your punch.
    May 2017
    Missouri
    24
    22
    Quote Originally Posted by Barry Weeks View Post
    Ejector Pins on order....Thank you!!!!!!!!!!!
    Jan 2007
    Flushing/Flint, Michigan
    7,712
    385
    6430
    They can be drilled with a diamond plated pin, a high speed spindle attachment and lots of coolant but I try to break them first as above unless I'm really worried about screwing up the hole a tad.
    Bob
  5. Likes Racer-X, Joe Miranda liked this post
    Jul 2006
    Hillsboro, New Hampshire
    7,376
    1740
    5127
    Bob
    Yup, I've done that using the regular mill spindle, but granted that was a ~14mm drill, so easier to accommodate the low rpm. Slow feed, helixed in at about .0007"/turn, used two pins for ~.75" of broken drill.
    If the "hood" is too thick to punch through you can try using a 1mm diamond pin with a tiny helix from that side, you should only have to go a little before you break through to the full hole. Diamond doesn't like cutting steel, but keep the bit cool and well flushed and it'll last for a little while.
    If it shows signs of burning, stop and replace, then keep going. Don't let bits of broken diamond embed into the part, that's bad (you'll need a laser as a truly last resort).
  7. Likes Racer-X liked this post
  8. #6
    Sep 2006
    SW Wisconsin
    496
    15
    115
    If the bit was coming though as it broke I would have it upside down blowing air in the exit side and tapping it on the side with a small hammer. Might shake it loose and blow it out.
    Ed.
  9. Likes Racer-X, Billtodd liked this post
  10. #7
    Dec 2007
    Massachusetts, USA
    802
    257
    546
    How much access do you have inside the "hood" if any and what tolerances/ finish do you have to hold?
    JR
    Edit
    I know you said unobtainiun but can you say the material or at least it's properties?
  11. #8
    Nov 2013
    Utah
    4,501
    1188
    2480
    THIS is good information, so you cannot burn out diamond? Sorry not an EDM guy.
    R
  12. #9
    Jul 2006
    7,376
    1740
    5127
    R
    I think compacted diamond (PDC) can be EDM'd when the binder is eroded, but diamond pins use particles of natural or synthetic diamond, which I think can't be burned as they're high-temp insulators. If someone knows different please correct me.
  13. #10
    Oct 2013
    New Jersey
    1,083
    903
    Diamond is kind of amazing. It is carbon, but a non conductor of electricity, yet conducts heat better than copper!
  14. #11
    Nov 2013
    Utah
    4,501
    1188
    2480
    Quote Originally Posted by garyhlucas View Post
    https://youtu.be/cJX1REQB12o
    Thought it was funny, yes I understand, that is fascinating.
  15. #12
    Johnny Larue Guest
    Quote Originally Posted by Racer-X View Post
    i'll bet a RAM EDM can get that out...if theres room for a drill then theres room for an electrode...use tungsten/carbide rod...or tungsten copper if you have it also....and I have done this before too....put in a heated jewelry cleaner that buzzes and put drill upside down with room for it to come out so raise job up...let cleaner vibrate pieces out and or whole drill...the heat of the cleaner will enlarge the hole sometimes and the vibration will shake it out
    PS...I have RAM EDM'ed crystal before also...but its very exacting and you must determine which way the crystal grains run...it took 3 days to go about .05 deep and it was a tungsten electrode with steel settings....example ON 003 OFF 025 MA 01 I.P 1.5 SV 04 and so on
  16. #13
    Johnny Larue Guest
    here is an old school way that is similar to jewelry cleaner method
  17. #14
    Jan 2007
    wales.uk
    1,155
    124
    174
    I read that diamond is actualy transparent to heat, it offers zero resistance, fascinating.
    Mark
