Drilling a smooth hole without tool marks
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 61
    Mar 2014
    Nevada
    70
    6
    Default Drilling a smooth hole without tool marks
    I am having a lot of trouble finding a shop that can drill a through hole in stainless steel, the though hole is about 1" deep x 3/32 I need it to be smooth free of tool marks all the way through. Could you folks please recommend a process to do this? Thank you very much in advance.
    Aug 2005
    Tacoma Washington
    1,344
    87
    127
    Drill undersized then ream??
    May 2007
    Massachusetts
    843
    13
    73
    Drills aren't really finishing tools. I find that feeding them at .011 X diameter feedrate minimizes the chip scraping that causes most tool marks. That and 1/2 diameter pecks. Reaming is better for good finishes, and gun drilling gives an even better finish.
    May 2012
    Mid-Iowa, USA
    3,497
    3467
    2057
    Sounds like you need a burnished surface.
  5. Likes i_r_machinist, BR3 liked this post
    Jan 2013
    canada
    861
    299
    422
    Have them ream your hole, cheers
    Sep 2005
    South Carolina USA
    4,478
    2154
    1307
    Or hone it after drilling/reaming, for even a better finish.
  8. Likes ADFToolmaker liked this post
  9. #7
    Mar 2001
    Switzerland
    2,532
    2291
    1096
    Neo6, give a little more info. All the above is good advice and will get you great holes, but what is your size tolerance? what's your actual desired finish- just free of scoring or polished? how many holes in this plate, 1, 5, 300? how straight, how perpendicular to the plate faces, and what tolerance on hole location? And maybe most importantly, what's your budget? Any half decent machine shop would know what the fellows above have said, perhaps they are working to a price for you?
    Fill us in.
  10. #8
    May 2005
    Interior British Columbia
    2,326
    242
    715
    Quote Originally Posted by Neo6 View Post
    How smooth? Quantify! You may be looking for finish requirements that are out of line for what use the part is, or you may not be conveying your need in a manner that makes the shops think that you will amount to more than a low-dollar headache when there is paying work to be done. If you quantify the surface finish requirement, then you are able to accurately convey how smooth. You may think something that is nowhere near as perfect as it can get, is quite adequate for your needs. The guy that has to make it gets told "perfect" and he's starting to figure out how to get a temperature controlled room full of very expensive measuring equipment paid for... Perfect is expensive. How expensive does it need to be.
    Tolerances? Again, quantify and write down.
    What kind of stainless steel? Some cut better than others. Some are just misery.
    That purpose is the part? Some folks won't touch anything that looks sketchy for any amount of money. Gun parts, drug paraphernalia, etc.
    Cheers
    Trev
  11. Likes BR3 liked this post
  12. #9
    Feb 2007
    Myrtle Point, Oregon USA
    340
    55
    249
    Quote Originally Posted by beege View Post
    Under 12X, gundrilling looks like it was done with an axe....ream then lap.
  13. #10
    Jun 2012
    Michigan
    10,196
    3459
    3644
    If the job was large enough a special might drill and then ream in one hit but likely too costly and increased tool length might cause location problems. Drill and ream two operations and so also time and tooling. Could burnishing or ball burnishing fit this need? The very best drill sharpening with perhaps a split point to make center better for somewhat less tool marks.. but yes a drill is not a reamer. *A second OD margin (double margin) would help... but again that is a special.
    Perhaps not that special from this source.
    http://www.panamericantool.com/pdf_c...drills_PAT.pdf
    Special Drill and Reamer a source for a good tool for a better price.
    But Pan at $2.07 for a 3/32... SD&R might not beat that price... wow that is a good price. flute length 1 1/4 so not many re-sharps (if any) but for that price it doesn't matter.
  14. #11
    Oct 2006
    williamsburg va
    7,882
    839
    1743
    Two things will leave a bad looking hole: A slightly bent drill(will leave spiral scratches,especially in large size drills),and chips will scratch the hole in deep holes. I'd suggest the shop try to get straighter drills,and do more pecking. Beyond that,you'll have to pay extra for reaming.
    A straight small drill can be selected by rolling the bit against a counter top under the finger. Look at the drill to see if it has a wobble when rolling. They'd probably think that would be a PITA,though. Even "good" brand drills can have a curve to them.
    How about drilling the holes with a straight flute solid carbide drill,and lots of pecking?
  15. #12
    Oct 2009
    Anacortes, WA USA
    534
    179
    Uh, everything leaves toolmarks. First you have to figure out what surface finish is acceptable.
  16. #13
    Aug 2013
    NY
    2,298
    984
    799
    Drilling? DRILLING?
    If you need a *perfect* hole you probably need to BORE the hole.
  17. Likes Mike C. liked this post
  18. #14
    Mar 2011
    Huron
    1,355
    1909
    846
    I've had pretty good luck with four flute core drills in steel, but core drills are getting hard to find. I have also heard good things about OSGs 3 flute drills for steel, but I have not tried them.
  19. #15
    Oct 2013
    st,louis mo
    673
    349
    Default Bore, indeed,chuckle,chuchle
    Quote Originally Posted by Spyderedge View Post
    Drilling? DRILLING?
    Say you drill a .086 hole 1 inch deep . What boring bar would work. In the olden days we would say a boring bar for this would look like a fly out on the end of a toothpick.
  20. Likes Bobw, sable, BR3, gmatov, allloutmx liked this post
  21. #16
    Jan 2013
    Ohio
    84
    29
    Would EDM work? Question of no answer.
  22. #17
    Mar 2013
    Missouri
    1,841
    1285
    1002
    more info would be helpfull.
    What about edm? it is kinda slow compared to drilling. time would increase.
  23. #18
    Nov 2004
    Birmingham, AL
    13,228
    6615
    2561
    Reaming and stainless is usually a bad combination. To much rubbing on the flutes, the part work hardens and things get nasty. I'm in the single point boring camp.
  24. #19
    Nov 2003
    5,051
    176
    1559
    Both boring and honing have been suggested. The OP was talking about a 3/32" diameter hole, wasn't he? Do they really make boring bars or hones in such small sizes? Can someone post a link to such a tool?
    Or do you have to make your own? If so, how?
  25. Likes gmatov liked this post
  26. #20
    Jul 2008
    Sydney, Australia
    3,726
    2056
    1287
    Quote Originally Posted by EPAIII View Post
    Sure, why not. I'm away at the moment but re meme for sure that Kaiser do a micro boring head, and ism sure there would be many others. 2 mm isn't small in the micro world. I wouldn't however expect the Joe Average machine shop to have facilities to bore this small however and you'd need to ask around. Having said that, I wouldn't expect any significant tool marks for a decent drill unless it's a hack job.
    To answer the OP, in stainless I would bore it, and if that wasn't smooth enough then lap it.
