Drilling stacked sheet metal
Results 1 to 14 of 14
    Mar 2019
    Wisconsin
    Default Drilling stacked sheet metal
    We often make these large parts from 1/8 to 1/4 stainless sheets. They typically have 50-400 holes that have a +/- .001 tolerance. I know the best way would be to have a laser or waterjet rough the holes and finish them in a mill, but that isn't an option. Currently we are working on 35"x55" sheets and are really struggling to get enough support under them to drill without massively deforming the sheets. Does anyone have any advice on what else we could try?
    Nov 2010
    UNITED KINGDOM
    976
    193
    236
    I had some 4 foot long 3 inch wide strips of stainless steel sheet to drill once with rows of 3/8” holes.
    Used double side tape and 1 inch plywood strips as a backing.
    Mar 2019
    Wisconsin
    Maybe I'll see if the boss will go pick up some plywood.
    Jan 2005
    CANADA
    Saskatchewan
    10,222
    1392
    3674
    Quote Originally Posted by Cplbooth54618 View Post
    It seems to me that your stated tolerance is far tighter than you can achieve with drills alone. Are you also reaming them all?
  5. Likes JohnEvans, rcoope liked this post
    Mar 2019
    Wisconsin
    Circle milling to the finished size
    Jun 2012
    Michigan
    9,960
    3358
    3569
    QT; [Circle milling to the finished size] with an end mill?
    Might you grind the end mill to a drill point. That way having one feed entering the hole as the end mill OD would be in place to circle mill..The time savings applied to drill feed speed so making a better drill hole. Yes a center cutting end mill might also work..(center cutting end mills should have 10 to 15* end clearance.)
    Yes the +- .001 is a bugger even with circle milling.
    Mar 2019
    Wisconsin
    These plates have a total of 792 .688 holes to finish. So for.cost savings we typically drill them then finish with an end mill. The problem is supporting them for the drilling. These parts are usually run in only 2-8 piece runs and aren't always the same hole size and location. Ideally I'd like to see the boss either get a water jet or find a shop with one who could rough the holes that way. But until then we struggle finding ways to support the part without deforming it.
  9. #8
    Oct 2005
    14,858
    I wonder if you could punch the holes ?
  10. #9
    Jan 2019
    Arizona
    590
    45
    198
    Particle board works better than plywood, but it will deteriorate with coolant fast, I would use a thicker sheet of plastic its pretty darn flat if not just face mill it.
    as far as the fastest way to do them I would think drill and then boring with a boring head from sanvik or kenametal or type of insert style .but you didnt say what hole size. so a carbide reamer might be best. for that matter what ss type. all this is going to make a difference on what type of tooling you could use.
    programs simple to run, easy to edit no need for other sizes as well.
  11. #10
    Jan 2019
    Tennessee
    456
    139
    120
    like Doug ask, a turret punch? A Piranha laser-punch-drill machine? use a reamer in the drill head for finished hole.
  12. #11
    Sep 2015
    431
    22
    180
    I’ve heard issues with machining water jet parts. Apparently the abrasive becomes embedded in the material and causes excessive tool wear.
    You may want to consider building a vacuum table to hold the sheet down. A ball end mill may make a nice two in one cutter that can drill through then go directly to opening up the holes to size.
  13. #12
    Oct 2005
    14,858
    Quote Originally Posted by memphisjed View Post
    I was thinking more on the lines of a finn power punch, or similar machine machine.
    How close is a punched hole ?
    Size should be very close.
  14. #13
    Jun 2012
    Michigan
    9,960
    3358
    3569
    The very tough cardboard Alro Steel uses to stack steel might be considered. Agree not so good for water jetting.
  15. #14
    May 2007
    Massachusetts
    1,420
    461
    1218
    What type of machine are you doing this work in ?
    I worked as a consultant at a place that made vibration isolation tables. These tables would have hundreds of drilled,C/sunk and tapped holes in 4 X 8 sheets of 1/8 thick stainless. This work was done in a large bridge type milling machine with an aluminum sub plate. The work was held down with clamps and vacuum.
    Make Chips Boys !
    Ron
