Sir grindalot
- May 23, 2020
I have a model 15 ,70's vintage. Its a real pain to bring it up on stroke because the ruler scale is so small. Once you get both ends approximate then you dial it in with the set up indicator. It scares the hell out of me because i always feel that the tail stock and head stock are not in sync. The elevation screws never correspond numerically. But somehow i always get it to grind a good rod journal. I must be close to exact because i can plunge grind and get no lap line taper on a sm blk crank rod journal is .0002 at worst. for production work on a manual machine i feel its "commerically acceptable"
Has any one put DRO 1 axis on a storm vulcan crank grinder??? I am getting ready to attempt it on my machine looking for ideas from someone who is running one with DRO successfully.
