Warrensmith
- Oct 14, 2018
Anyone contemplating the purchase of a new DRO try before you buy, unfortunately some of the newer units around do not perform well.
We recently purchased a new Fagor 40i-TS because of its RPM and surface speed displays and that function works well however the positional display is noticeably laggy ie. when you move the hand controls it takes time for the display to respond and after you have stopped the position keeps updating for a period of time. Unless you are stationary the display is about 2 update cycles (1/2 sec.) behind the machine which makes it very hard to use.
The new fancy LCD displays might look good but they come with a processing time penalty and Fagor have not prioritised the functionality so position is updated in real time.
We have tried working through this with their engineers however they are blaming everything but their poor programming. Unfortunately our experience over the last 10 years has not been good when purchasing new equipment it seems the new norm is do no testing just push it out the door quickly.
W
W
