Dumb question, but here I go. Can I mill depths deeper than my flute length?
Results 1 to 17 of 17
    Sep 2010
    Anchorage, Alaska, USA
    645
    234
    125
    Default Dumb question, but here I go. Can I mill depths deeper than my flute length?
    Hi there;
    I have been scared to cut slots deeper than my flute length, even though shank and flute are the same diameter...
    The obvious problem is chip evacuation...
    But, is it true I can't bury the flutes?
    I mean, I won't D.O.C. beyond one diameter.. but wondering if I will get away with it, or kill end mills.
    Mark
    Sep 2007
    Washington
    5,257
    200
    1590
    You will get some burning above the flutes if you are running deeper than the flute length. While the shank is technically the same diameter as the flutes (except reduced-shank or necked endmills), the tool is not cutting EXACTLY at the diameter of the flutes. Just a bit under, but just a bit under is enough to allow the shank to rub.
    Sometimes you can go a LITTLE deeper, like .03" or so, as the flutes don't just suddenly stop right at the nominal flute length.
    Regards.
    Mike
  3. Likes snowshooze, bryan_machine, empwoer liked this post
    Sep 2007
    Washington
    5,257
    200
    1590
    Quote Originally Posted by snowshooze View Post
    Huh? Which DOC are you talking about? Most endmills have flute lengths that are like 2x or 3x the diameter.
    I think one of us is confused.
    Regards.
    Mike
  5. Likes snowshooze liked this post
  6. #4
    Apr 2019
    Arkansas
    886
    290
    327
    What he/she said is clear.
    Your stepdown is one thing and total depth is another as you know.
    You can go past your flute length in total depth but you will rub the shank of the tool. You can buy or have made relieved neck tools to do as your wanting.
  7. Likes snowshooze, Dumpster_diving, empwoer liked this post
  8. #5
    Sep 2010
    645
    234
    125
    Oh, just go to the surface grinder with the spin-jig and skinney it up?
    Mark
  9. Likes Bobw, Mark Rand liked this post
  10. #6
    Sep 2010
    645
    234
    125
    Rule of thumb here is 1/2 diameter.
    I violate that occasionally, at the expense of chip-load.
  11. #7
    Sep 2010
    645
    234
    125
    Well, that part isn't at issue.
    I step down generally around 1/2 diamter.
    If I do that enough, I run outta flutes.
  12. #8
    Nov 2003
    5,056
    176
    1560
    If this is a one-off or a two-see or three-see, I say go for it. With careful steps and clean out the chips after each pass.
    If this is a production situation and many parts must be cut, then just break down and buy a couple of longer end mills.
    As for the rubbing thing, use a good cutting fluid; one with good lubrication properties.
  13. Likes snowshooze liked this post
  14. #9
    Sep 2010
    645
    234
    125
    Will, cutting a production fixture.
    .375" Mill, .3967" Slots, but .500" deeper than flutes.
    78 slots, 1.375" long, 1.5 deep. 6061.
    Blaser 755
  15. #10
    Apr 2019
    Arkansas
    886
    290
    327
    Blaser 755
    Just buy the right tooling
    Sent from my Pixel 3 using Tapatalk
  16. Likes Bobw liked this post
  17. #11
    Oct 2019
    NICARAGUA
    106
    41
    I would just grind a little off the shank.
  18. #12
    Oct 2019
    NICARAGUA
    106
    41
    30 seconds on a bench grinder, it doesnt need to be smooth or concentric, only smaller.
  19. Likes Casady Machine, Red James, Bobw, jrmach liked this post
  20. #13
    Nov 2017
    288
    182
    196
    If you feed successive passes in opposite directions, cutter deflection will create a slot slightly wider than the cutter.
  21. #14
    Feb 2014
    Sunny South West Florida, USA
    2,889
    10712
    3287
    Series Display - M.A. Ford
    3/8" Endmill, 1.5" flute length... Cheaper than you think.
    4 Flute, Corner Radius - Variable Pitch, Reduced Neck price right on the website... About $100 depending on what you pick.
    Call these guys, tell them you want this endmill, but with a reduced neck, they'll likely modify it for you at no, or minimal charge. Less than $50. S42-003 – MITGI
  22. Likes camscan, Bobw liked this post
  23. #15
    Aug 2004
    Virginia
    2,346
    176
    909
    I have done it a few times in a pinch. Yes you can buy the proper mill but not on a Saturday night when the job needs to be done by Monday morning. What I have done is is clamp a course diamond file in the mill vise. Bring the mill in the mill holder up to the file and run it up and down a few times with the Y feed. Take a few thousandths off the shank and it will not rub.
  24. Likes as9100d, Bobw liked this post
  25. #16
    Oct 2013
    New Jersey
    1,112
    946
    A reduced shank will be stiffer than more flute length so you might actually get more speed and a better finish.
  26. #17
    Dec 2015
    Illinois
    437
    144
    251
    These would work well for you but you would want to make sure you have the right sized collet for the shank.
    Reduced Shank 3/8 Variable flute X .359 shank X 3.5 long .010 Radius - Made in U MariTool
    Or this for 2x as much but uses a more standard size collet.
    http://www.harveytool.com/ToolTechIn...mber=943224-C3
