Strostkovy
Titanium
- Oct 29, 2017
We have a serious dust issue in our shop. From welding, grinding, laser cutting, powder coating, and sand blasting we have too much dust circulating around. When sunlight shines inside you see it, and if you leave a cup of water out it's undrinkable the next day. We always have to wash or wipe down customer's parts regardless of how long they have sat before pickup.
We have decent ventilation in the welding booths, we have moved sandblasting into an outdoor booth, have the correct dust collector for our laser, etc. The powder coating booth uses MERV 12 furnace filters and is pretty bad, but it's on the other side of the shop and is far from the only source of dust. The oven is unventilated and smokes a fair bit every time a batch of parts is baked.
Aside from getting better powder booth ventilation and putting a vent hood over the oven, what else should we do? The laser dust collector works well but does allow some dust out during blowoff. It's a similar story for everything else. Works okay but not okay enough.
We are considering getting or making some air cleaners using hepa filters or powder coating type filters. Does anyone do anything similar and how is it working for you?
This is a 27000 square foot fabrication shop. Welders and sandblasters have supplied air respirators, and our powder coater has an adequate respirator as well. But other operators do not, and dust accumulation on electrical panels and machinery is a significant maintenance concern.
While we will be improving our point of use filtration, I don't think it's possible to catch everything.
What do you think the investment into a low dust shop would be and how much power do you think it would consume?
