I am considering purchasing a lathe with an ASA A1-5" spindle nose. I have found a few drawings and pictures on the interwebs, but there is very little information regarding the pros, cons, and 'how to use them'. It seems that this was the precursor or alternate to the D1-5" spindle nose that takes the cam-lock chucks.
When I looked at the lathe, the owner removed the chuck by simply holding the chuck against the spindle and removing three bolts from the back side of what appeared to be a back plate. He then lifted the chuck off. Does this mean that with the A1-5 system the backplate is always left on the spindle nose?
If so, that seems like a pretty inconvenient setup which would require one to re-true the chuck onto this backplate every single time it is replaced. Each of the chucks had a counterbored step that mated to the backplate (one was 0.132" deep and the other was 0.201" deep). That isn't the 'short taper' is it? The owner said that there is very slight play between them to adjust for any runout. That's fine as long as it holds using those three bolts, but I can't see a way to remove the backplate and chuck assembly together from the spindle nose without removing the chuck first.
Unless I am missing something obvious (which is most likely the case) this spindle nose might be a deal breaker. Any additional information, tips, tricks, etc. (especially videos) of this A1-5 system would be greatly appreciated.
Thanks in advance!
JJ
Thanks in advance!
JJ
