Electric motor question for milling machine
Results 1 to 8 of 8
    Jan 2021
    Massachusetts
    Default Electric motor question for milling machine
    I recently acquired a MSC gear head milling machine model number 09512914 the motor is a 3 phase motor and would like to swap it out for a single. Is there a source for these motors besides MSC? Im not against buying one from them but thought I could source one cheaper elsewhere. They want almost $600.00 for one. The tag on the motor isn't much help. The current motor is model #
    CT-18-17-01-09-C(1)-3-02-1-04-1-07-01-08-1-04-6-05
    Don't even know what all those mean. Its a 1 horse flange mount with a 3/4 shaft.
    Thanks Mike
    Oct 2005
    21,183
    Quote Originally Posted by MichaelEverson1 View Post
    Thanks Mike
    https://www.mscdirect.com/product/details/09512914
    Get a VFD, should be under $200 for that motor size.
  3. Likes eKretz, steve45, paulz, 9100 liked this post
    Feb 2006
    Indiana
    13,777
    787
    4555
    And get a VFD with a 120 V single phase input rated for a 1 HP motor. It will be much cheaper than a special motor and run off any household electrical outlet. Plus, you may find the variable speed feature fun to play with.
    AC drives (VFD's) can be bought on eBay or from various online retailers. Practical Machinist has a VFD forum where you can ask about specific models and sources.
    https://www.practicalmachinist.com/v...rters-and-vfd/
    Larry
    Apr 2004
    Modesto, CA USA
    8,424
    1594
    A VFD will give you variable speed and fast electrical braking. That motor is likely expensive as it probably has a longer then normal shaft that most off the shelf ones will lack.
    Bil lD
    Sep 2006
    Sacramento County, California
    4,336
    2781
    1670
    As mentioned several times above, changing to single phase from a three phase motor on a milling machine is not wise either from the operational standpoint or financially.
    Either a VFD or an RPC would be the obvious choice for most having only single phase in their shop.
    In my case I went with a home-built RPC for about $200. On my 3 hp Webb mill a new motor would run me about $900. No thanks.
    May 2020
    Minnesota
    233
    92
    63
    Milling machines for whatever reason tend to have fancy-schmancy custom spec motors on them. If not for that I'd just look up the frame size and plunk an equivalent one in there. VFD and walk away.
    Jul 2005
    Eastern PA
    1,123
    216
    806
    Looks like a C face motor. If so, C face motors are very adaptable and any generic 1 HP should be adapted to fit. We just adapted a $60 EBay C face to a Bridgeport. Easy peasy and saved a bunch........Bob
  9. #8
    Sep 2006
    4,336
    2781
    1670
    Quote Originally Posted by Just a Sparky View Post
    The typical Bridgeport or BP clone motor for a variable drive has an extra long/large-diameter shaft that carries the sheaves for the drive. Also, the motor bolts directly to the drive housing.
    It would be very difficult to adapt a different motor to the task. If the need is simply to be able to use single phase power, then it would be far less trouble to go to a VFD or an RPC. I'm just saying.....
