Electrically-insulating material selection
Page 1 of 2 12 LastLast
Results 1 to 20 of 24
    Jul 2021
    Idaho
    19
    7
    21
    Default Electrically-insulating material selection
    Any suggestions for a material that is:
    --Machinable with conventional carbide/hss tooling
    --Electrically insulating
    --Has a coefficient of thermal expansion ideally below 25ppm/degF (~45ppm/degC)
    ...and then it'd be nice if it...
    --costs less than $5/cubic inch in quantities of ~20 cubic inches.
    This is a low-voltage device, less than 10V across the part. Macor would work but it's overkill.
    It'd be good to discover something less expensive for this application.
    Apr 2004
    Modesto, CA USA
    8,958
    1776
    How thin can it be? for 10 volts I would think any plastic,dry wood or marble would work. wiring is pvc, nylon, teflon. I bet pex, polyethelene, rubber hose would all work. Also superglue seems to insulate.
    I will be following this thread because I need to make a new bushing for my self igniting propane torch. The spark wire comes through a metal handle casting. That bushing is a hard black plastic that cracked before. When it cracked the spark just shorted out, well below the gas flow. I took it out and super glued it back. It worked fine for a few years until I kicked the torch over and cracked the plastic. Lost a piece so I need to make a complete bushing this time. Think I will try something more flexible like nylon tubing.
    Bill D
    Apr 2004
    Modesto, CA USA
    8,958
    1776
    I think the first elctro magnet used wire insulated with strips of silk ripped from his wife's wedding dress. Later they would dip the wire in shellac.
    Jul 2021
    Idaho
    19
    7
    21
    The part is rectangular and needs to be about 0.15" thick. The need for a low coefficient of thermal expansion rules out many materials that would otherwise work fine. Marble is an interesting idea and has a CTE in the right range...wonder how hard it'd be to cut some 4-40 threads in it.
    Oct 2010
    Oregon
    5,882
    5891
    2284
    Some variants of polyimide will have thermal expansion that low, but you'll have to read spec sheets.
    Many species of wood also meet the spec, but you probably want something homogenous and isotropic, like MDF. You can laminate 1" layers of MDF, or get it in thicker sheets (harder to source).
    [Added in edit] Oh, now I see you want it thin, not thick.
    May 2009
    Canandaigua, NY, USA
    3,443
    181
    1778
    I think some phenolics will do that. Or, maybe something from Aremco?
  7. Likes Borealis, Ron Hofer liked this post
    Nov 2018
    Michigan
    861
    473
    586
    Most all of the usual suspects in the plastics world will do the job if you get glass fiber reinforced versions of the polymer, it really brings the CTE down (into the 30s (x10e-6/°C) for the most part, down to the 20s for a few of them).
  9. Likes Borealis liked this post
  10. #8
    Mar 2007
    On Elk Mountain, West Virginia, USA
    2,292
    1098
    835
    Soapstone, minerological name Talc
  11. Likes Borealis liked this post
  12. #9
    Jun 2013
    492
    399
    214
    How about epoxy/glass?
  13. #10
    Dec 2008
    Vt USA
    9,687
    1745
    3578
    Micarta doesn't fit the bill? or G10?
  14. #11
    Jul 2021
    Idaho
    19
    7
    21
    Quote Originally Posted by CalG View Post
    The CTE on phenolic-type materials tends to be closer to 100ppm/degC. I'm not sure about G10...do they make that in thicker sections? The only stuff I have in the shop is the typical 0.06" circuit board stuff...but it's glass-filled, so maybe the CTE is good.
  15. #12
    Jun 2013
    492
    399
    214
    I have epoxy glass (G10) in 3/4". Linear coef. = 36.
    McMaster-Carr has it in many thicknesses.
  16. #13
    Jul 2021
    Idaho
    19
    7
    21
    Conrad, thanks for bringing my attention to Aremco. Never heard of them before but bookmarked it immediately after seeing all the unusual materials they offer.
    Magnetic, great idea worth looking into... Didn't know soapstone & talc are the same thing. Looks like it's easy to find online and the prices are reasonable.
    Boxcar, thanks for the suggestion to look for glass-filled versions of the plastics.
  17. #14
    Nov 2003
    6,154
    225
    2124
    I do not have a specific material to recommend, but I would urge you to be sure whatever you pick does have it's electrical resistance/conductance specified. A well respected company that built professional audio equipment ordered some plastic panels to use as terminal boards. They assumed the plastic they specified would be an insulator. Turns out it was a black color and that was produced by adding carbon powder to the mix. It drove them nuts trying to find where the cross talk was being introduced.
  18. #15
    Mar 2005
    Indiana
    6,548
    2352
    2543
    Yes G-10 is made very thick. I've got some that's over an inch. And it fits the low CTE requirement.
  19. #16
    Feb 2014
    FL
    4,700
    14153
    5768
    I think PEEK fits the bill, minus the price... Although I understand the industrial grade stuff is quite a bit cheaper than the medical grade I'm used to?
  20. Likes Mike1974 liked this post
  21. #17
    Oct 2005
    22,785
    Glastic board ?
    Try Haysite in Erie, Pa.
  22. #18
    Apr 2004
    Modesto, CA USA
    8,958
    1776
    If it needs to be threaded it may be easier to cast it or injection mold it.
    Bill D
  23. #19
    Jun 2012
    Michigan
    6,296
    5881
    4026
    Quote Originally Posted by Borealis View Post
    We have a repeat job of G10 that uses 4" thick material.
    Check out Thyssen Krupp, that's where we buy our G10 and phenolics.
    thyssenkrupp Materials NA: Materials Supplier and Supply Chain Expert
  24. #20
    Jun 2013
    492
    399
    214
    Here's where I buy it.
    McMaster-Carr
