gregormarwick
- Feb 7, 2007
- Aberdeen, UK
Totally clueless here so could use a bit of advice. I am quoting on a 17-4PH part that has some features that can only be machined by sinker EDM (complex profile that has some square internal corners, blind bottom with square corners, vertical walls, quite deep - think long skinny electrode). No problem and we do parts of this family quite regularly.
Problem in this case is the customer requires an N6 finish on the EDM'd surfaces. Our goto EDM place doesn't want to guarantee better than N9, although I'd say he's playing it safe - previous parts have been comfortably better than that. All the same, N6 is really pushing it for sinker EDM as I understand it.
I am looking for ways to post process the EDM'd surfaces and my first thought was electropolishing as geometry will not allow conventional polishing tools, at least not into the corners or near the bottom.
So is electropolishing a good solution here? Can it be applied selectively to the surfaces I require or will the entire part have to be processed? The EDM'd surfaces are not tight tolerance, at around ±.1mm, but there are other machined features on the part with tight tolerances that I'm worried would be affected.
